    How can I track my error on onewire library
    onewirelopy4nameerrords18b20
    5 Posts 3 Posters 928 Views 3 Watching
    • pierrot10P Offline
      pierrot10
      Hello
      I am trying to use the DS18x20 sensor.
      For this I download the library onewire and I pasted it into /flash/lib/onewire.py
      Then I upload my code from Atom.
      I am surprised to read that error:
        File "main.py", line 5, in <module>
        File "/flash/lib/onewire.py", line 1, in <module>
      NameError: name 'I' is not defined
      Because of that message I checked the line of the file /flash/lib/onewire.py and I Can NOT see the caracter I, which should be a variable undefined. As I does not exsist, how can I solve my problem?
      I imported onewire.py as the following
      from onewire import DS18X20 #This is at line 5, as state in the error message
      from onewire import OneWire # for DS18D20
      Cheers and thank, have a nice evening
      pierrot10P 1 Reply Last reply Reply Quote 0
        pierrot10 @pierrot10
        @pierrot10 However, I just read that file from the exemple
        boot.py
        I have not copy. Sorry for my question, but this is mandatory? Because it look like UART and do not use UART. That make sens?
        Tks
        Cheers
        L robert-hhR 2 Replies Last reply Reply Quote 0
          livius @pierrot10
          @pierrot10
          look at example
          https://github.com/pycom/pycom-libraries/tree/master/examples/DS18X20
            robert-hh @pierrot10
            @pierrot10 No, you do not need boot.py.
            The error is strange, and looks for me like a pymakr "surprise". If you can connect with ftp, check that the files are where you expect them and what is in the files.
              pierrot10 @robert-hh
              @robert-hh Hello. Thnak for your reply. Apparently, after the transfer, a H (or a I, etc) is added as the first caracter, as the following:
              H#!/usr/bin/env python3
              OneWire library for MicroPython
              It the reason why I got that error. The problem, I can not correct it directely because after saving it, the file become newer than the source and it will be overwritten at the next sync.
              Then I look at the other lib file and I observed than none of them has that line. I remove and it work until I got a message stating, it can not imported DS18X20.
              I first open my file with textwrangler, then I open it with Atom and I observed, the text was terribly formated (A lot on the same line).
              I reformat it and it's works but not always..
              Now the problem it state a
                File "main.py", line 9, in <module>
                File "/flash/lib/onewire.py", line 2
              SyntaxError: invalid syntax
              here is line two:
              OneWire library for MicroPythonß
              class OneWire:
              What is wrong?
              Then I gave a spave (return key) before the """ and I got the same error message
              NameError: name 'A' is not defined
              Then how can sync my onewire file without a formatting issue and with a unwish caracter before the first line?
              Does I need to check something on Atom?
              Thabk for your help
              EDIT:
              OK. Problem seems to be solved. I copy again the content of onewire.py to /Flash/lib/onwire.py and on Atom, at the bottom right, I changed LF to CRLF.
              The problem does not appear any more.
              That funny because my main.py has LF (and not CRLF) and I do not have this problem with main.py
