    New beta firmware updater 1.13.1.b4
    Scheduled Pinned Locked Moved Beta Announcements & Development News
    beta updater
    8 Posts 2 Posters 2.1k Views 3 Watching
    • X Offline
      Xykon administrators
      Beta Version 1.13.1.b4 is now available:
      Here are the download links:
      Windows download
      MacOS download
      Linux downloads
      The main reason for this release is to produce a unified updater that also supports the upcoming release of Pybytes. You shouldn't see anything Pybytes related in this release (please let me know if you do).
      There are also a few bug fixes so it's still worth upgrading to this release.
      Please let me know if you encounter any issues.
      Christian Ehlers
        robert-hh @Xykon
        @xykon Hello @xycon. This is a good tool for maintaining devices. I have a request for an extension. At the moment, switching into bootloader mode either uses a FTDI or PIC mode. the FTDI mode requires a GPIO0->GND jumper and a manual reset. However, operations which include several steps do not seem to work this way, like for instance erase_fs.
        Also, is it possible to implement the bootloader-mode transition the way esptool initially supports, by toggling RTS and DTR? I made few e baseboards myself with the standard two transistor logic, avoiding the hazzle with the PIC.
        • X Offline
          Xykon administrators @robert-hh
          @robert-hh Hello Robert,
          Thanks a lot for the feedback.
          I don't have a board to test switching into firmware update mode using Espressif's reset method, so I can't really test if it works. I will add support to manually enable the reset. I think the reason we disabled it in the first place was because it was crashing the PIC based boards so it shouldn't be a problem to enable it by default in ftdi mode but before I do this I want to make sure I've tested it on all operating systems.
          I also found the bug that was preventing some commands to not run properly when running the tool with the -c / --continuation option. This should be fixed in the next release (probably Sunday or Monday).
          Christian Ehlers
            robert-hh @Xykon
            @xykon Thanks for the response. The espressif's reset method works with almost any ESP32 and ESP8266 board, like those of Wemos or Sparkfun. But I can test that if you like.
            • X Offline
              @robert-hh The new release is out now. Can you please test the new -r / --reset option to see if that's working?
              Christian Ehlers
                robert-hh @Xykon
                @xykon Yes, that seems to work. Thanks a lot.
                X 1 Reply Last reply Reply Quote 1
                • X Offline
                  @robert-hh Great thanks a lot. I'll leave it as is for now as I don't want to risk breaking something else by activating this reset by default.
                  If you have any other ideas to make the tool more useful please let me know.
                  Christian Ehlers
                    robert-hh @Xykon
                    @xykon For me it is sufficient as it is now.
