    Air Time calculation in (Micro)Python
    loraair timecalculation
    4 Posts 4 Posters 854 Views 4 Watching
    • rcolisteteR Offline
      rcolistete
      As it is a common question how to calculate the air time of LoRa packets, so I post a Python 3/MicroPython script to calculate the data rate and airtime. Links about the calculations :
      LoRa data rate calculator
      LoRa air time calculator
      Spreadsheet for LoRa airtime calculation
      LoRa.py (needed for Python3, not needed by Pycom MicroPython as it already has in 'network.LoRa' submodule)
      BW_125KHZ = 0
      BW_250KHZ = 1
      BW_500KHZ = 2
      CODING_4_5 = 1
      CODING_4_6 = 2
      CODING_4_7 = 3
      CODING_4_8 = 4
      LoRaAirTimeCalc.py :
      # LoRaAirTimeCalc.py v0.1 (26/04/2018) for normal Python 3 (for PC) or Pycom MicroPython
      # By Roberto Colistete Jr (roberto.colistete at gmail.com)
      # from network import WLAN, LoRa   # For Pycom MicroPython
      import LoRa   # For Python3
      import struct
      from math import ceil
      # Using Pycom constants for bw and cr, calculates the DR (datarate) in bps
      def dataratetheoretical(sf, bw, cr):
         if bw == LoRa.BW_125KHZ:
             bwv = 125
         if bw == LoRa.BW_250KHZ:
             bwv = 250
         if bw == LoRa.BW_500KHZ:
             bwv = 500
         crv = 4/(4 + cr)
         return 1000*sf*bwv*(crv)/2**sf
      # Air time (in seconds) theoretical calculation for LoRa-RAW, where there is a default preamble of 8 bytes plus 5 bytes of CRC, etc
      def airtimetheoretical(payloadsize, sf, bw, cr):
             bwv = 125
             bwv = 250
             bwv = 500
         if sf in [11,12]:
             lowDRopt = 1
             lowDRopt = 0
         tsym = (2**sf)/(bwv*1000)
         tpreamble = (8 + 4.25)*tsym # Preamble with 8 bytes
         numbersymbolspayload = 8 + max(ceil((8*payloadsize - 4*sf + 28 + 16)/(4*(sf - 2*lowDRopt)))*(4 + cr),0)
         tpayload = numbersymbolspayload*tsym
         tpacket = tpreamble + tpayload
         return tpacket, tpreamble, tpayload, tsym, numbersymbolspayload
      Usage example (within ipython3), the first number is the airtime in seconds :
      In [1]: from LoRaAirTimeCalc import *
      In [2]: airtimetheoretical(20, 10, LoRa.BW_125KHZ, LoRa.CODING_4_5)
      Out[2]: (0.37068799999999996, 0.100352, 0.27033599999999997, 0.008192, 33)
      Another example, showing the airtime in ms (miliseconds) :
      In [2]:  [(payloadsize, airtimetheoretical(payloadsize, 8, LoRa.BW_125KHZ, LoRa.CODING_4_5)[0]*1000) for payloadsize in range(1, 33)]
      Out[2]:
      [(1, 51.711999999999996),
       (2, 51.711999999999996),
       (3, 61.952),
       (4, 61.952),
       (5, 61.952),
       (6, 61.952),
       (7, 72.19200000000001),
       (8, 72.19200000000001),
       (9, 72.19200000000001),
       (10, 72.19200000000001),
       (11, 82.432),
       (12, 82.432),
       (13, 82.432),
       (14, 82.432),
       (15, 92.672),
       (16, 92.672),
       (17, 92.672),
       (18, 92.672),
       (19, 102.91199999999999),
       (20, 102.91199999999999),
       (21, 102.91199999999999),
       (22, 102.91199999999999),
       (23, 113.15199999999999),
       (24, 113.15199999999999),
       (25, 113.15199999999999),
       (26, 113.15199999999999),
       (27, 123.392),
       (28, 123.392),
       (29, 123.392),
       (30, 123.392),
       (31, 133.632),
       (32, 133.632)
      In this GitLab repository/folder "LoRaAirTimeCalc" it has better documentation and examples.
      J L 2 Replies Last reply Reply Quote 3
        jmarcelino @rcolistete
        @rcolistete
        That's very useful. Thank you for for posting.
          lloureiro @rcolistete
          @rcolistete very nice and usefull, values equal to TTN Data page. Thanks a lot
          • K Offline
            kjm
            How do your calcs compare with
            m=lora.stats()
            print('TxTime(ms)',m[7])
