    Error using PySense temp/hum sensor
    pysensewipy 3.0
    3 Posts 2 Posters 968 Views 2 Watching
      jhollan3
      I'm trying to read the temperature from the PySense board and am running to errors I can't figure out. Here is my code, which I based on the example for PyTrack and the API documentation:
      from SI7006A20 import SI7006A20
      from pysense import Pysense
      py = Pysense()
      sensor = SI7006A20()
          print(sensor.humidity())
          print(sensor.temperature())
      This is the error in Pycom Console
        File "main.py", line 2, in <module>
      ImportError: no module named 'SI7006A20'
      MicroPython v1.8.6-849-83e2f7f on 2018-03-19; WiPy with ESP32
      What am I doing wrong? Thanks for the help!
        jmarcelino @jhollan3
        @jhollan3
        You probably need to add the sensor libraries to your lib/ folder on the device.
        Please check if you have SI7006A20.py there (directly on /flash/lib)
          jhollan3 @jmarcelino
