    Interface Wipy with water flow meter
    dac4-20ma sensorwipytransceiver
    2 Posts 2 Posters 653 Views 2 Watching
    • R Offline
      Ricardo85
      For interfacing water flow meter with WIPY, I wanted to send the digital data to get converted into analog output of 4-20mA current range (which is very old and good solution to control the meter) but as I am new to 4-20mA current loop field, What is the best low power DAC module to interface flow meter easily with wipy?
      your suggestion will be appreciated
        jmarcelino @Ricardo85
        Hi @ricardo85
        Can you share what water flow meter you're planning to use?
        Are you sure you want the WiPy to be a transmitter or a receiver?
