    connect 2 wipy2.0 by WiFi
    17 Posts 3 Posters 5.8k Views 3 Watching
      livius
      I try to connect two WiPy2 by WiFi
      one WiFi is in AP mode (default settings)
      second is in STA and try to connect to first
      but i can not connect and every few seconds i got entry - what this is?
      n:6 0, o:6 1, ap:255 255, sta:6 1, prof:6
      n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      i have in loop:
      while not wlan.isconnected():
      		machine.idle()
      the whole session:
      wifi_sta
      mode : sta(24:0a:c4:00:a8:be)
      livius
      wipy-wlan-6ec2
      vnet-509F64
      UPC0838976
      UPC Wi-Free
      TP-LINK_9A6D1E
      keke
      2.4G-vnet-1C0A58
      UPC8578324
      DIRECT-y6-BRAVIA
      UPC0040392
      UPC Wi-Free
      UPC1387285
      UPC Wi-Free
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      state: 5 -> 0 (2)
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      state: 5 -> 0 (2)
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      state: 5 -> 0 (2)
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      state: 5 -> 0 (2)
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      state: 5 -> 0 (2)
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      state: 5 -> 0 (2)
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      state: 5 -> 0 (2)
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      state: 5 -> 0 (2)
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      state: 5 -> 0 (2)
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      state: 5 -> 0 (2)
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
        daniel
        Can you share the code that you are using to try this? Thanks.
        Cheers,
        Daniel
          livius
          I have not access to my home WiPy now
          but there is really simple code - i write it from my memory:
          First WiPy. in STA mode
          wlan = WLAN(mode=WLAN.STA)
          nets = wlan.scan()
          print(str(nets))
          wlan.connect(ssid='wipy-xxxx-a8', auth=(WLAN.WPA2, 'www.pycom.io'))
                machine.idle()
          print('connected')
          Second WiPy run in default AP mode without modification
          and i never got 'connected' message
          only output like:
          state: 0 -> 2 (b0)
          state: 2 -> 3 (0)
          state: 3 -> 5 (10)
          add 0
          all with recent software 0.9.5
            livius
            with firmware 9.6
            it repeat
            I (36355) wifi: n:6 0, o:6 1, ap:255 255, sta:6 1, prof:6
            I (36476) wifi: n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
            I (36476) wifi: state: 0 -> 2 (b0)
            I (36479) wifi: state: 2 -> 3 (0)
            I (36487) wifi: state: 3 -> 5 (10)
            ets Jun  8 2016 00:22:57
            configsip: 0, SPIWP:0x00
            mode:QIO, clock div:2
            load:0x3fff9010,len:8
            load:0x3fff9018,len:812
            ho 0 tail 12 room 4
            load:0x40078000,len:3692
            load:0x4009f000,len:944
            entry 0x4009f1f0
            rtc v134 Oct 20 2016 12:36:18
            XTAL 40M
            I (824) phy: phy_version: 246, Nov 18 2016, 17:30:07, 0, 0
            tcpip_task_hdlxxx : 3ffdef94, prio:18,stack:2048
            frc2_timer_task_hdl:3ffdfa9c, prio:22, stack:2048
            I (968) wifi: pp_task_hdl : 3ffdfc68, prio:23, stack:8192
            mode : softAP(24:0a:c4:00:a8:bf)
            dhcp server start:(ip: 192.168.4.1, mask: 255.255.255.0, gw: 192.168.4.1)
            wifi_sta
            livius
            wipy-wlan-6ec2
            SoftAP-9F
            vnet-509F64
            UPC0838976
            UPC Wi-Free
            2.4G-Vectra-WiFi-B7C11C
            TP-LINK_9A6D1E
            UPC Wi-Free
            2.4G-vnet-1C0A58
            keke
            DIRECT-y6-BRAVIA
            UPC Wi-Free
            UPC0040392
            I (5100) wifi: n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
            I (6076) wifi: state: 0 -> 2 (b0)
            I (6077) wifi: state: 2 -> 3 (0)
            I (6081) wifi: state: 3 -> 5 (10)
            I (16081) wifi: state: 5 -> 0 (2)
            I (16081) wifi: n:6 0, o:6 1, ap:255 255, sta:6 1, prof:6
            I (16202) wifi: n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
            I (16203) wifi: state: 0 -> 2 (b0)
            I (16207) wifi: state: 2 -> 3 (0)
            I (16212) wifi: state: 3 -> 5 (10)
            I (26212) wifi: state: 5 -> 0 (2)
            I (26213) wifi: n:6 0, o:6 1, ap:255 255, sta:6 1, prof:6
            I (26334) wifi: n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
            I (26334) wifi: state: 0 -> 2 (b0)
            I (26338) wifi: state: 2 -> 3 (0)
            I (26354) wifi: state: 3 -> 5 (10)
            I (36354) wifi: state: 5 -> 0 (2)
            this is my code - in file 'wifi_sta.py' and i execute it from boot.py as execfile('wifi_sta.py'):
            from network import WLAN
            print('wifi_sta')
            pycom.heartbeat(0)
            pycom.heartbeat(1)
            pycom.rgbled(0x00ff00)
            nets = wlan.scan()
            for net in nets:
               print(str(net.ssid))
            if not wlan.isconnected():
            	#wlan.ifconfig(config=('192.168.4.2', '255.255.255.0', '192.168.4.1', '192.168.4.1'))
            	#wlan.connect('wipy-wlan-a8be', auth=(WLAN.WPA2, 'www.wipy.io'), timeout=5000)
            	wlan.connect('wipy-wlan-6ec2', auth=(WLAN.WPA2, 'www.wipy.io'), timeout=5000)
            	pycom.heartbeat(0)
            	pycom.heartbeat(1)
            also if you uncomment line
            and also if i change
            		machine.idle()
            to
            pass
            time.sleep_ms(10)
              livius
              Any help? Can someone successfully connect two Wipy 2 together?
              A 2 Replies Last reply Reply Quote 0
                abilio @livius
                @livius. I'm going to run some tests later and come back to you with a result.
                  abilio @livius
                  @livius, I tried something similar to your setup, and wasn't able to reproduce it. Using two LoPys (internally just a WiPy with the LoRa radio attached), I proceed to connect over serial port to both. Did this in one of them over the REPL:
                  nets = wlan.scan() # just to get a list
                  print(str(nets))
                  wlan.connect(ssid='lopy-wlan-be54', auth=(WLAN.WPA2, 'www.pycom.io')) # put your ssid here
                  # waited for a few seconds (counted to 10)
                  wlan.isconnected() # this printed true
                  That's the most trivial test I could run. To rule out some possible causes, I want to ask you to try the same, using your own ssid, over serial REPL, and come back with the results to me.
                  PS: I also tried the version with the loop, and it worked the way it's supposed
                    livius
                    testet from REPL - result are near to positive
                    >>> import os
                    >>> os.uname()
                    (sysname='WiPy', nodename='WiPy', release='0.9.6.b1', version='v1.8.6-40-gd10463e on 2016-11-25', machine='WiPy with ESP32')
                    >>> nets = wlan.scan()
                    >>> print(str(nets))
                    [(ssid='UPC0838976', bssid=b'\x8c\x04\xff\xf5\xae\x8a', sec=4, channel=1, rssi=-42), (ssid='wipy-wlan-6ec2', bssid=b'$\n\xc4\x00n\xc3', sec=3, channel=6, rssi=-42), (ssid='UPC Wi-Free', bssid=b'\x8e\x04\xff\xf5\xae\x8c', sec=5, channel=1, rssi=-44), (ssid='vnet-509F64', bssid=b'pT\xd2b\xc4\xda', sec=4, channel=11, rssi=-49), (ssid='livius', bssid=b'\x000O\x8b\x0c\x08', sec=4, channel=9, rssi=-50), (ssid='2.4G-Vectra-WiFi-B7C11C', bssid=b'\x84\x00-  <', sec=4, channel=1, rssi=-65), (ssid='2.4G-vnet-1C0A58', bssid=b't\x85*3 \xd7', sec=4, channel=1, rssi=-75), (ssid='UPC1387285', bssid=b'\x8c\x04\xff{bL', sec=4, channel=1, rssi=-79), (ssid='UPC Wi-Free', bssid=b'\x8e\x04\xff{bN', sec=5, channel=1, rssi=-80), (ssid='TP-LINK_9A6D1E', bssid=b'\xb0Hz\x9am\x1e', sec=3, channel=1, rssi=-80), (ssid='keke', bssid=b'\xb0Hz\xbe\xf6\xa4', sec=3, channel=4, rssi=-84), (ssid='Misza', bssid=b'\x00\x1d~\x91]\x07', sec=3, channel=6, rssi=-88), (ssid='vnet-A6EA06', bssid=b'\x0cT\xa5E*\xc9', sec=4, channel=11, rssi=-88), (ssid='vnet-EC0D8E', bssid=b'T\xbe\xf7\nEN', sec=4, channel=11, rssi=-88), (ssid='UPC Wi-Free', bssid=b'\x02&$>\xaa\x9b', sec=5, channel=7, rssi=-90)]
                    >>> wlan.connect(ssid='wipy-wlan-6ec2', auth=(WLAN.WPA2, 'www.pycom.io'))
                    >>> I (283825) wifi: n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
                    I (284800) wifi: state: 0 -> 2 (b0)
                    I (284804) wifi: state: 2 -> 3 (0)
                    I (284820) wifi: state: 3 -> 5 (10)
                    I (284836) wifi: connected with wipy-wlan-6ec2, channel 6
                    wlan.isconnected()
                    True
                    but here we have different timings between commands - in real script i have not pauses between commands as i have b etween typing by REPL
                    and as you can see above there is same but only once response with lines:
                      abilio @livius
                      @livius, ok, at least we know you get similar results to me. Let me try again to reproduce yours. Thanks a lot for your feedback.
                        livius
                        i can provide you my files
                        if you will be unable to reproduce issue
                          abilio @livius
                          @livius, I've been caught in several things but I didn't forget you. If you can place your code in pastebin and pass the link, that will let us reproduce it perfectly ;)
                            livius
                            the files are:
                            http://konwertuj.com/content/main.py.txt
                            http://konwertuj.com/content/boot.py.txt
                            http://konwertuj.com/content/wifi_sta.py.txt
                            http://konwertuj.com/content/wifi_ap.py.txt
                            remove .txt extension after download
                              livius
                              with newest firmware 9.7 same
                              UPC1334070
                              I (6398) wifi: n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
                              I (7374) wifi: state: 0 -> 2 (b0)
                              I (7376) wifi: state: 2 -> 3 (0)
                              I (7380) wifi: state: 3 -> 5 (10)
                              I (17381) wifi: state: 5 -> 0 (2)
                              I (17381) wifi: n:6 0, o:6 1, ap:255 255, sta:6 1, prof:6
                              I (17502) wifi: n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
                              I (17503) wifi: state: 0 -> 2 (b0)
                              I (17504) wifi: state: 2 -> 3 (0)
                              I (17507) wifi: state: 3 -> 5 (10)
                              I (27508) wifi: state: 5 -> 0 (2)
                              and this is on WiPy in AP mode
                              I (1018844) wifi: station: 24:0a:c4:00:a8:be leave, AID = 1
                              I (1018844) wifi: n:6 1, o:6 1, ap:6 1, sta:255 255, prof:6
                              I (1018982) wifi: n:6 1, o:6 1, ap:6 1, sta:255 255, prof:6
                              I (1018982) wifi: station: 24:0a:c4:00:a8:be join, AID = 1, n, 40U
                              I (1028985) wifi: station: 24:0a:c4:00:a8:be leave, AID = 1
                              I (1028986) wifi: n:6 1, o:6 1, ap:6 1, sta:255 255, prof:6
                              I (1029109) wifi: n:6 1, o:6 1, ap:6 1, sta:255 255, prof:6
                              I (1029109) wifi: station: 24:0a:c4:00:a8:be join, AID = 1, n, 40U
                                livius
                                this is what i got when i added sleep_ms(100) between every commands
                                maybe this is much more informative (file name - wdev.c)
                                ho 0 tail 12 room 4
                                entry 0x4009f1f0
                                XTAL 40M
                                I (858) phy: phy_version: 246, Nov 18 2016, 17:30:07, 0, 0
                                tcpip_task_hdlxxx : 3ffdf30c, prio:18,stack:2048
                                frc2_timer_task_hdl:3ffdfe14, prio:22, stack:2048
                                I (1005) wifi: pp_task_hdl : 3ffeb6cc, prio:23, stack:8192
                                wdev.c 1327
                                and wipy hang totally
                                but after manual restart same info as before:
                                I (67836) wifi: state: 5 -> 0 (2)
                                I (67836) wifi: n:6 0, o:6 1, ap:255 255, sta:6 1, prof:6
                                I (67957) wifi: n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
                                I (67958) wifi: state: 0 -> 2 (b0)
                                I (67962) wifi: state: 2 -> 3 (0)
                                I (67998) wifi: state: 3 -> 5 (10)
                                  abilio @livius
                                  @livius, thanks for your status update. We're still looking into this issue. I'll come back at you when I get more information.
                                    livius
                                    with newest firmware still the same :(
                                    >>> os.uname()
                                    (sysname='WiPy', nodename='WiPy', release='1.0.0.b1', version='v1.8.6-251-g2fb950d on 2016-12-16', machine='WiPy with ESP32')
                                    ho 0 tail 12 room 4
                                    entry 0x4009f1f0
                                    tcpip_task_hdlxxx : 3ffedb2c, prio:18,stack:2048
                                    I (2440) wifi: frc2_timer_task_hdl:3ffef74c, prio:22, stack:2048
                                    I (2451) wifi: pp_task_hdl : 3fff20c8, prio:23, stack:8192
                                    I (3427) wifi: mode : softAP (24:0a:c4:00:a8:bf)
                                    wifi_sta
                                    I (3613) wifi: mode : sta (24:0a:c4:00:a8:be)
                                    vnet-509F64
                                    wipy-wlan-6ec2
                                    SoftAP-9F
                                    UPC0838976
                                    UPC Wi-Free
                                    2.4G-vnet-1C0A58
                                    TP-LINK_9A6D1E
                                    keke
                                    UPC Wi-Free
                                    DIRECT-y6-BRAVIA
                                    UPC0040392
                                    UPC Wi-Free
                                    vnet-EC0D8E
                                    I (7001) wifi: n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
                                    I (7977) wifi: state: init -> auth (b0)
                                    I (7983) wifi: state: auth -> assoc (0)
                                    I (7989) wifi: state: assoc -> run (10)
                                    I (17989) wifi: state: run -> init (2)
                                    I (17990) wifi: n:6 0, o:6 1, ap:255 255, sta:6 1, prof:6
                                    I (18111) wifi: n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
                                    I (18111) wifi: state: init -> auth (b0)
                                    I (18113) wifi: state: auth -> assoc (0)
                                    I (18128) wifi: state: assoc -> run (10)
                                    I (28128) wifi: state: run -> init (2)
                                    I (28129) wifi: n:6 0, o:6 1, ap:255 255, sta:6 1, prof:6
                                    I (28250) wifi: n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
                                    I (28250) wifi: state: init -> auth (b0)
                                    I (28255) wifi: state: auth -> assoc (0)
                                    I (28269) wifi: state: assoc -> run (10)
                                    I (38269) wifi: state: run -> init (2)
                                    I (38270) wifi: n:6 0, o:6 1, ap:255 255, sta:6 1, prof:6
                                    I (38391) wifi: n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
                                    I (38392) wifi: state: init -> auth (b0)
                                    I (38396) wifi: state: auth -> assoc (0)
                                    I (38404) wifi: state: assoc -> run (10)
                                    I (48404) wifi: state: run -> init (2)
                                    I (48404) wifi: n:6 0, o:6 1, ap:255 255, sta:6 1, prof:6
                                    I (48526) wifi: n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
                                    I (48526) wifi: state: init -> auth (b0)
                                    I (48528) wifi: state: auth -> assoc (0)
                                    I (48545) wifi: state: assoc -> run (10)
                                    I (58546) wifi: state: run -> init (2)
                                    I (58546) wifi: n:6 0, o:6 1, ap:255 255, sta:6 1, prof:6
                                    I (58667) wifi: n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
                                    I (58668) wifi: state: init -> auth (b0)
                                    I (58673) wifi: state: auth -> assoc (0)
                                    I (58677) wifi: state: assoc -> run (10)
                                    I (68677) wifi: state: run -> init (2)
                                    I (68678) wifi: n:6 0, o:6 1, ap:255 255, sta:6 1, prof:6
                                    I (68799) wifi: n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
                                    I (68800) wifi: state: init -> auth (b0)
                                    I (68802) wifi: state: auth -> assoc (0)
                                    I (68808) wifi: state: assoc -> run (10)
                                    I (78809) wifi: state: run -> init (2)
                                    I (78809) wifi: n:6 0, o:6 1, ap:255 255, sta:6 1, prof:6
                                    I (78930) wifi: n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
                                    I (78931) wifi: state: init -> auth (b0)
                                    I (78934) wifi: state: auth -> assoc (0)
                                    I (78939) wifi: state: assoc -> run (10)
                                    I (88940) wifi: state: run -> init (2)
                                    I (88940) wifi: n:6 0, o:6 1, ap:255 255, sta:6 1, prof:6
                                    I (89061) wifi: n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
                                    I (89062) wifi: state: init -> auth (b0)
                                    I (89065) wifi: state: auth -> assoc (0)
                                    I (89074) wifi: state: assoc -> run (10)
                                      livius
                                      this is amazing that this was so simple like wrong password from some old documentation :)
                                      connected two wipy2 together
                                      ho 0 tail 12 room 4
                                      entry 0x4009f1f0
                                      tcpip_task_hdlxxx : 3ffedcb0, prio:18,stack:2048
                                      I (1843) wifi: frc2_timer_task_hdl:3ffef8a8, prio:22, stack:2048
                                      I (1849) wifi: pp_task_hdl : 3fff2170, prio:23, stack:8192
                                      I (2825) wifi: mode : softAP (24:0a:c4:00:a8:bf)
                                      wifi_sta
                                      I (3008) wifi: mode : sta (24:0a:c4:00:a8:be)
                                      wipy-wlan-6ec2
                                      UPC0838976
                                      UPC Wi-Free
                                      vnet-509F64
                                      TP-LINK_9A6D1E
                                      2.4G-vnet-1C0A58
                                      UPC Wi-Free
                                      keke
                                      UPC1387285
                                      vnet-EC0D8E
                                      UPC Wi-Free
                                      UPC8578324
                                      DIRECT-y6-BRAVIA
                                      STAWIK iNTERNET
                                      UPC Wi-Free
                                      I (6100) wifi: n:6 1, o:6 0, ap:255 255, sta:6 1, prof:6
                                      I (7074) wifi: state: init -> auth (b0)
                                      I (7077) wifi: state: auth -> assoc (0)
                                      I (7086) wifi: state: assoc -> run (10)
                                      I (7101) wifi: connected with wipy-wlan-6ec2, channel 6
                                      MicroPython v1.8.6-251-g2fb950d on 2016-12-16; WiPy with ESP32
                                      >>> Connected to AP wipy-wlan-6ec2 channel 6I (17086) wifi: pm open, type:0, st: 0, sending null data: 0
