    LoRaMAC freeze
    loramacdistancelora range
    4 Posts 3 Posters 895 Views 3 Watching
    • V Offline
      Vicky_
      Hi pycom team,
      I have made an experiment using 2 lopy to get the distance LoRa can transmit at my housing area. The longest distance is 309m with obstacles (houses), I encountered a problem, the gateway will stop working or freeze at random time intervals. I thought I lost signal but when I get near to the node, it still not sending any signal. I have to restart to make it reconnect. Any idea what is the problem and solution how can I make it auto connect or auto restart?
      Thank you.
        robert-hh @Vicky_
        @vicky_ Which code configuration are you using? Some of the examples from the lib? Without knowing, it is hard to tell what happens.
          jcaron @Vicky_
          @vicky_ Also, what version of the firmware are you running (on both LoPys)?
          • V Offline
            Vicky_
            @jcaron @robert-hh so sorry for late, because these 2 days im quite busy
            I just updated both lopy to the latest version
            after i update i have problem connect to Adafruit, which is OSError:-1
            I combine my code with this tutorials link
