    LoPy - oscillator frequency
    lopy4oscillatorfrequency
    5 Posts 2 Posters 901 Views 2 Watching
    • M Offline
      m.toriello
      Hi there,
      is there any chance to set in code the internal oscillator frequency of the LoPy4?
      Thanks in advance
        jmarcelino @m.toriello
        Hi @m-toriello
        Which internal oscillator do you mean exactly?
        • M Offline
          m.toriello
          Hi @jmarcelino ,
          I mean the microcontroller's oscillator. For example the Microchip PICs hve some registers to set the internal oscillator properly (typically it's called INTOSC). I was wondering if there is something like this in LoPy.
          Thank you
            Thanks @m-toriello
            The LoPy4 uses a ESP32 microcontroller where the clock is driven from an external crystal. If you program it directly in C (using ESP-IDF) you can select different clock speeds at configuration (80, 160, 240 Mhz) but - because of the many timing critical peripherals implemented - in MicroPython this isn't currently supported and the clock is fixed at 160Mhz.
            • M Offline
              m.toriello @jmarcelino
              @jmarcelino
              Ok, thank you!
              Best regards
