GPS error: (None, None) coordinates
  • Hello,
    I am using a Pytrack with my FiPy, and trying to get a location with the L76GNSS lib provided by Pycom.
    When getting coordinates, the method always gives me empty data, even after 20 minutes. I tried indoor and outdoor, always the same results.
    Is there some kind of initialisation that must be done before ?
    Does someone have the same issues ?
    Edit: I have two FiPy/Pytrack at my disposal and they both gives the same output.
    Thank's
  • Thank's for your replies !
    I though that the module couldn't catch signal for indoor, and this is why I tried outdoor. I had buildings around me but clear a view of sky for about 20 minutes and still no data.
    I've tried printing the frames, and I only get invalid data:
    '$GPGLL,,,,,000200.800,V,N*70\r\n'
    • V means invalid data,
    • N means no fix for GPS
    I started digging into the protocol specification for L76 device and saw multiple commands to configure it.
    Do you know some that may help getting better signal ? (I found Active Interference Cancellation for example, but it is activated by default).
    Thank's again !
  • Without any additional hard-/software?
    Have you tried to print the sentences read from the GPS chip?
  • Hi @fstaine
    GPS indoors will just not work and outdoors you need clear view of the sky.
    Perhaps that's the problem?
