    Wipy 3 issues
    boot.pyheartbeat
    4 Posts 2 Posters 751 Views 2 Watching
      jmpratt
      My WiPy 2 just died so I'm trying to get my WiPy 3 up and running out of the box. Did the firmware upgrade so now it executes boot.py and connects to my network. Now the heartbeat LED is False after boot.py runs. I thought that was weird so I explicitly set heartbeat(true) in boot.py but it won't flash. From the REPL, it shows heartbeat(false). Any ideas what is causing the heartbeat to go false? Main.py is the default, blank version. Here's my boot.py:
      # boot.py -- run on boot-up
      # can run arbitrary Python, but best to keep it minimal
      import network
      from machine import SD
      from machine import UART
      from network import WLAN
      import os
      pycom.heartbeat(True)
      # Set up WLAN
      wlan = WLAN() # get current object, without changing the mode
      ssid     = 'Mynet'
      password = 'xxxxxxx'
      ip       = '192.168.1.50'
      net_mask = '255.255.255.0'
      gateway  = '192.168.1.1'
      dns      = '192.168.1.1'
      uart = UART(0, 115200)
      os.dupterm(uart)
      def init():
          wlan = WLAN(mode=WLAN.STA)
          wlan.ifconfig(config=(ip, net_mask, gateway, dns))
      def connect():
          wlan.connect(ssid, auth=(WLAN.WPA2, password), timeout=5000)
          while not wlan.isconnected():
          cfg = wlan.ifconfig()
          print('WLAN connected ip {} gateway {}'.format(cfg[0], cfg[2]))
      def set():
          init()
          if not wlan.isconnected():
              connect()
      set()
      # Set up server
      #server = network.Server()
      #server.deinit()
      #server.init(login=('YOUR_USERNAME','YOUR_PASSWORD'),timeout=600)
      # SD card support
      sd = SD()
      os.mount(sd, '/sd')
        robert-hh @jmpratt
        @jmpratt I anything connected to P2?
          jmpratt @robert-hh
          @robert-hh nope. Just sitting in an expansion board 2.0. nothing connected.
            robert-hh @jmpratt
            @jmpratt Since there is no configuration data on a WiPy that could get lost, you could try to make a complete erase using esptool.py and then reload the firmware.
