    Lopy4 serial connection troubleshooting
    seriallopy4linux
    3 Posts 2 Posters 834 Views 2 Watching
    • R Offline
      Re
      Hello everyone,
      I just received two LoPy4, as well as one expansion board.
      Trying to access the LoPy4 via Serial, I have troubles sending it command.
      It seems I can receive data just fine, but I cannot send data to the LoPy4 module.
      What I receive is the following, using screen /dev/ttyACM0 115200
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:2
      load:0x3fff9010,len:12
      ho 0 tail 12 room 4
      load:0x3fff9020,len:388
      load:0x40078000,len:11584
      load:0x4009fb00,len:848
      entry 0x4009fc9c
      MicroPython v1.8.6-798-gebbcca48-dirty on 2017-10-31; LoPy4 with ESP32
      So it looks like the board is working fine, but yet I cannot enter data, I cannot type enter, etc.
      Any idea what I might do wrong?
      Thank you
        robert-hh @Re
        @re
        a) check the cable, if it is a full USB cable or just a charging cable
        b) check the jumpers on the expansion board. At least the RX and TX junpers must be in place
        c) you might need to update the frmware of the expansion board. I assume you are using expansion board 3, since you just received it.
        • R Offline
          Re
          I found out what was the problem: not the cable, not the up to date expansion board3, but simply the out-of-date lopy4 firmware.
          Updating it fixed it!
