    WDT and deepsleep
    wdtdeepslereset
    5 Posts 3 Posters 1.5k Views 3 Watching
      Jardar
      Hi
      Does the WDT also trigger in deepsleep? And is the WDT cleared after deepsleep wakeup?
        alexpul
        Quick answer is no and yes.
        The code below set the WDT for 8 s and deep sleep for 100 s and my device doesn't wake up after 8 s.
        from machine import WDT
        wdt = WDT(timeout=8000) #WDT for 8 s
        machine.deepsleep(100*1000) #deep sleep for 100 s
        WDT is reset after deep sleep wake up because this wake up resets the board and clears all libraries (WDT can't run if it's library isn't imported). Always best to try some code to test your questions!
        • K Offline
          kjm
          You can make the wdt persistent through deepsleep
          pycom.wdt_on_boot(True)          # enable WDT on boot
          pycom.wdt_on_boot_timeout(60000) # reboots after a minute if no wdt.feed
          which is nice given the gears penchant for reverting to it's default 4s blue flash mode. Be careful though, too short a timeout & you don't get a chance to enter pycom.wdt_on_boot(False) before it reboots again
            alexpul @kjm
            @kjm Just to clarify, your code makes the WDT turn on automatically when the device wakes up but it will not trigger a WDT reset while the device is in deep sleep, correct?
            • K Offline
              kjm @alexpul
              @alexpul correct
