    Converting float to bytes
    convert to byte
    6 Posts 3 Posters 943 Views 3 Watching
      AidanRTaylor
      Hello - I'm trying to convert an ambient sensor readout into bytes so I can squeeze it down the LoRa tube! I can't seem to get the float.hex() attribute to work, I get this back: AttributeError: type object 'float' has no attribute 'hex'.
      The Python3 docs say that float.hex() is a built in type, am I missing something here?
      I tried the following:
      temp = float.hex(sensordata)
      temp = sensordata.hex()
      Both return the same attribute error. Where am I going wrong? Is there a module I need to include? Here is the main module from my project:
      import bme680
      from bme680.i2c import I2CAdapter
      from machine import Pin
      import struct
      # Config pin:
      configPin = Pin('P21', Pin.IN, Pin.PULL_UP)
      # Setup I2C and BME680: P9/G16=SDA, P10/G17=SCL
      i2c_dev = I2CAdapter(1, pins=('P9','P10'), baudrate=100000)
      sensor = bme680.BME680(i2c_device=i2c_dev)
      # These oversampling settings can be tweaked to
      # change the balance between accuracy and noise in
      # the data.
      sensor.set_humidity_oversample(bme680.OS_2X)
      sensor.set_pressure_oversample(bme680.OS_4X)
      sensor.set_temperature_oversample(bme680.OS_8X)
      sensor.set_filter(bme680.FILTER_SIZE_3)
      config = configPin()
      if config:
              if sensor.get_sensor_data():
                  output = "{} C, {} hPa, {} RH, {} RES,".format(
                      sensor.data.temperature,
                      sensor.data.pressure,
                      sensor.data.humidity,
                      sensor.data.gas_resistance)
                  print(output)
                  temp = float.hex(sensor.data.temperature)
                  print(temp)
                  time.sleep(5)
        robert-hh @AidanRTaylor
        @aidanrtaylor use struct.pack() instead.
        T 1 Reply Last reply Reply Quote 1
          AidanRTaylor
          thanks, trying it out now (I already had stuct imported as you can see above :P)
            timh @robert-hh
            @robert-hh beat me to it ;-)
            struct.unpack('f',binascii.unhexlify(binascii.hexlify(struct.pack('f',1.234))))
            and using 'e' instead of 'f' for the format will mean the float uses 4 bytes in hex form. at the loss of precision but doubt you need that much for temp ;-)
              AidanRTaylor
              isn't unpack the opposite of what I want? I thought I would need pack
              Oh, I see you are showing me how to do both ;)
                @aidanrtaylor Yes, you need pack() to make a bytes string out of a float, and unpack() will convert that back.
                unpack() returns a tuple, wheras pack() in addition to a tuple accepts a single value.
