    Why MicroWebSrv not runnning on Wipy3.0 ?
    microwebsrvwipy3.0micropythonnetwork
    2 Posts 2 Posters 737 Views 2 Watching
      GDA45-78
      Hello everyboby, i need some help,
      I m using Wipy3.0 with the last firmware (1.18). I downloaded MicroWebSrv from https://github.com/jczic/MicroWebSrv
      I copied "main.py" to "start.py" and I m using this code in my Main.py :
      from network import WLAN
      # configure the WLAN subsystem in station mode (the default is AP)
      wlan = WLAN(mode=WLAN.STA)
      # go for fixed IP settings (IP, Subnet, Gateway, DNS)
      #wlan.ifconfig(config=('10.1.10.178', '255.255.255.0', '10.1.10.254', '10.1.10.178'))
      wlan.scan()     # scan for available networks
      wlan.connect(ssid='my_network', auth=(WLAN.WPA2, 'azerty123'))
      while not wlan.isconnected():
          pass
      print(wlan.ifconfig())
      With console into VS Code, I m using the command
      import start
      Nothing happens. Nothing to navigator. The command seems blocked.
      I am obliged to make a hard reset
      Someboby to help me.
        jczic
        If you want, I propose a new powerful embedded Web Server for MicroPython (and CPython) that supports route handlers, modules like WebSockets or PyhtmlTemplate and a lot of simultaneous requests.
        Mostly used on ESP32, Pycom WiPy, STM32 on Pyboard, ... Robust and efficient (thousands requests on CPython!)
        GitHub - Open Source - MIT.
        --> https://github.com/jczic/MicroWebSrv2 <--
        JC`zic
