    Upload failed.: OSError: [Errno 22] EINVAL with LoPy4 and PyMakr
    lopy4pymakrexpansion board
    2 Posts 2 Posters 553 Views 2 Watching
      christian_kohler
      I have a LoPy4 (version 1.18), plugged into an Expansion Board 2, and connected via USB to a Mac running Atom 1.27.2, and PyMakr 1.3.3
      I can upload some small projects without a problem, but one project is failing consistently, see below.
      Uploading project (main folder)...
      Safe booting device... (see settings for more info)
      Reading file status
      Creating dir lib
      [1/3] Writing file lib/sht31.py
      [2/3] Writing file lib/urequests.py
      [3/3] Writing file main.py
       Please reboot your device manually.
      OKTraceback (most recent call last):
        File "<stdin>", line 2, in <module>
      >OK>OKets Jun  8 2016 00:22:57
      rst:0x7 (TG0WDT_SYS_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff8028,len:8
      load:0x3fff8030,len:1728
      load:0x4009fa00,len:0
      load:0x4009fa00,len:14584
      entry 0x400a059c
      I did manage to upload it over FTP once, but that has not been a reliable route. Often when I connect to the LoPy AP and use FileZilla to connect to 192.168.4.1 I cannot get it to work.
      Status:      	Connecting to 192.168.4.1:21...
      Error:        	Connection timed out after 20 seconds of inactivity
      Error:        	Could not connect to server
      Any idea what is going on here?
      Christian
        robert-hh @christian_kohler
        @christian_kohler Did you set Filezilla to single link/passive mode? The number of simultaneous links have to be set in the server settings submenu->transfer settings for each connection.
        I'm using ftp all the time, and it is pretty reliable and fast. SInce I have Firfox open all the time anyhow, I prefer the FireFTP plugin.
