    LoPy LoRa documentation suggestion
    2 Posts 2 Posters 869 Views 2 Watching
    • B Offline
      borjam
      Hi :)
      I've been playing a bit with the LoPy and I've noticed a couple of quirks in the LoRa class that should be documented.
      When changing some of the parameters on the fly, like tx_power, sf or, if I remember well, coding_rate (I mean, with an initialized radio, calling lora.tx_power(new power) for example) transmission didn't work until I
      reconfigured the bandwidth again with lora.bandwidth(intended bandwidth).
      There seems to be some dependency so that changing one of the paramters on the fly requires some further initialization.
      Is it known?
        sakis @borjam
        Hi @borjam,
        Please feel free to file an enhancement issue at https://github.com/pycom/pycom-micropython/issues
        If you want you can even improve our LoRa documentation yourself. It's available at https://github.com/pycom/pycom-micropython/tree/master/docs/pycom_esp32. You can fork the repository, apply your changes, and submit a pull request.
