    Network Performance Measure with Pycom Board
    discussiongpypysensenb-iotperformance
    4 Posts 3 Posters 745 Views 3 Watching
    • le_wildfoxL Offline
      le_wildfox
      I'm currently using GPy + Pysense.
      Does anyone have any idea on how to measure network performance (E.g.: throughput, latency) using Pycom Board?
      I intend to compare wifi & nb-iot performance.
      Thank you for your help.
      Cheers!
      le_wildfox
      bmarkusB 1 Reply Last reply Reply Quote 0
      • bmarkusB Offline
        bmarkus @le_wildfox
        @le_wildfox said in Network Performance Measure with Pycom Board:
        Cheers!
        le_wildfox
        WiFi and NB-IoT are two different kind of animals. I dont't think it has too much sense to compare latency and throughput.
        le_wildfoxL 1 Reply Last reply Reply Quote 1
          le_wildfox @bmarkus
          @bmarkus said in Network Performance Measure with Pycom Board:
          Cheers!
          le_wildfox
          Hi Markus,
          Thanks for your response.
          Yes, so true.
          But, say, if I want to measure just for the nb-iot, do you think it's possible with a script running on the pycom board?
          Any idea on how to implement that?
          Cheers!
            jcaron @le_wildfox
            @le_wildfox I'm not very familiar with NB-IoT, but from what I understand, it is quite specifically designed to not offer great throughput or latency, as the priority is low power.
            The peak rate is between 20 and 250 kbits/s, and latency is counted in seconds... Not sure exactly what you expect to get...
