    Crash when connecting to my home Wifi router
    26 Posts 6 Posters 10.8k Views 6 Watching
    • M Offline
      macfreek
      Thanks. From that thread it seems that the culprit was IPv6 router solliciation (as needed for SLAAC, which is often used in conjunction with DHCPv4). It seems I was looking at the correct event, but the wrong packet. My apologies for that. I have not yet reproduced it, but this seems very likely. I will follow the other thread for the upstream bug. Could you report back here once upstream is fixed and a new firmware for the pycom boards is available?
        abilio @macfreek
        @macfreek, We'll report any progress here. Expect it to be included in the release after a solution is found :)
        • W Offline
          williamv
          good find @abilio !! i changed ipv6 settings on my wireless router Netgear R7000 from 6to4-tunnel to Disabled and have not seen the crash again for the last 30 min ;-)
            JF002 @abilio
            @abilio I disabled the IPV6 interface on my router, and indeed, my Lopy does not crash any more.
            I'll leave the IPV6 interface disabled for now, but this is a workaround until it is fixed in the firmware :)
              PCA
              @abilio @JF002 same result for me. No more crashes if the wifi router IPV6 interface is disabled...
                abilio @PCA
                @williamv, @PCA, @JF002, thank you all for your reports :)
                • M Offline
                  macfreek
                  Now that the bug has been found and fixed upstream, and merged into master, would you dare to take a stab at guessing a reasonable ETA before the upstream is released, and Pycom release a new firmware version? Is that a matter of days, around Christmas, next year, ...?
                  • R Offline
                    rdixey
                    I just loaded New firmware release 1.0.0.b1 on my LoPy and tested my WiFi connection and it worked without crashing. I see that this release included an Update to the latest IDF from Espressif, so I assume this addressed the problem. I glad this is fixed since I had no way to turn off IPv6 on my cable modem.
                    Thanks Pycom
                      JF002 @rdixey
                      Same for me, I updated to version 1.0.0.b1, re-enabled IPV6 on my router, and wifi does not seem to crash anymore.
                      I'll do more extensive test this afternoon :)
                      • W Offline
                        williamv
                        Same for me, upgraded firmware to 1.0.0.b1 on my LoPy, re-enabled IPv6 on router, happy puppy sinds then. Thank you for quickly fixing Pycom team!
                        • 1
                        • 2
                        • 2 / 2
