    Cellular LoRaWAN Nanogateway
    Scheduled Pinned Locked Moved Projects
    lora gatewaylora
    12 Posts 4 Posters 980 Views 6 Watching
    • M Offline
      mylescai
      Hey, does anyone know if it's possible edit the lorawan nanogateway code so that the device is connected via cellular (Cat M1) rather than wifi?
        lewis
        I was able to get it work just fine. The internet connection to the server worked fine. I'm having issues getting downlink messages to the lorawan nodes, but on AT&T LTE-M its working great.
          robert-hh @mylescai
          @mylescai the nanogateway opens a socket connection to the TTN server. So you just have to attach and connect the LTE link, and the go on with connecting to TTN.
          Edit: To be more specific. In nanogateway.py, function start(), at about line 140 the wifi is set up. At that place you can instead set up the LTE connection.
          M 2 Replies Last reply Reply Quote 0
          • M Offline
            Miguel Toscano G @robert-hh
            @robert-hh said in Cellular LoRaWAN Nanogateway:
            Hi Robert, help me please =D, ¿How can I instead set up the LTE connection ?
            • M Offline
              @robert-hh
              I changed config.py code for these:
              from network import LTE
              lte = LTE()
              lte.init()
              lte.attach(band=20, apn="internet.itelcel.com")
              print("attaching..",end='')
              while not lte.isattached()
              time.delay(0.25)
              print('.',end='')
              print(lte.send_at_cmd('AT!="fsm"'))
              print("attached!")
              lte.connect()
              print("connecting [##",end='')
              while not lte.isconnected():
              time.sleep(0.25)
              print('#',end='')
              #print(lte.send_at_cmd('AT!="showphy"'))
              print("] connected!")
              print(socket.getaddrinfo('pycom.io', 80))
              lte.deinit()
              #now we can safely machine.deepsleep()
              and now i know, I have to change this into nanogateway.py.... ¿but how ?
              self.wlan = WLAN(mode=WLAN.STA)
              self._connect_to_wifi()
                robert-hh @Miguel Toscano G
                @Miguel-Toscano-G All you have to do is start LTE and connect to the network. Once you have done that, you can run the nanogateway code as it is. I just tried that here with NB-IoT.
                For connecting to the LTE service, follow the examples.
                M 1 Reply Last reply Reply Quote 1
                • M Offline
                  @robert-hh Hi Robert, thank you for help me, I tried with the example "nanogateway" code with WiFi and its work good, but when I changed the config file with de LTE code. I get this IndentationError.
                  ----------- Console--------------
                  OK
                  attached!
                  connecting [##] connected!
                  [(2, 1, 0, '', ('18.195.176.111', 80))]
                  File "main.py", line 14, in <module>
                  File "nanogateway.py", line 99
                  IndentationError: unexpected indent
                  Pycom MicroPython 1.20.2.rc6 [v1.11-01f49f7] on 2020-02-28; FiPy with ESP32
                  Pybytes Version: 1.3.1
                  File nanogateway.py
                  line 99 refers to ssid y password
                             99        self.ssid = ssid
                             100        self.password = password
                  *** the main and nanogatawey files, I did not modify them. Only to the file "config", I delete all the wifi code, and paste the lte configuration, and also, I put the information telephone company.
                    @Miguel-Toscano-G Obviously the file is formatted wrong. Did you really copy the line numbers? If not, there is probably a mix of tabs and spaces in the file, which may be causes by the process of copying and storing.
                    • M Offline
                      @robert-hh you are correct, that was the error =D
                      • M Offline
                        @robert-hh Finally it is running on LTE cat m1 =D thanks... ¿Do you know, how can i use lte cat m1 and wifi on the same gateway at the same time? I want to connect my fipy with ttn using LTE CAT M1(its ready) and connect the same gateway with a laptop through wifi....
                          @Miguel-Toscano-G There was a discussion about simultaneous WiFi and LTE mode at the forum. As far as I recall the result, there was no clear control about which interface is used by the gateway for it's communication.
                          Do you use the FiPy in AP or STA mode?
                          • M Offline
                            @robert-hh So far, I have used the fipy connected to wify and I have also used the fipy with lte. I'm not sure what I'm using (Ap or STA).... but I only use one technology at a time (wifi or lte)
                            wifi code (config.py)
                            """LoPy LoRaWAN Nano Gateway configuration options"""
                            import ubinascii
                            WIFI_MAC = ubinascii.hexlify(machine.unique_id()).upper()
                            GATEWAY_ID = GATEWAY_ID = WIFI_MAC[:6] + "FFFE" + WIFI_MAC[6:12]
                            SERVER = 'router.us.thethings.network'
                            PORT = 1700
                            NTP = "pool.ntp.org"
                            NTP_PERIOD_S = 3600
                            WIFI_SSID = ''
                            WIFI_PASS = '
                            LORA_FREQUENCY = 903900000
                            LORA_GW_DR = "SF10BW125" # DR_0
                            LORA_NODE_DR = 0
                            LTE code (config.py)
                            """ LoPy LoRaWAN Nano Gateway configuration options """
                            import ubinascii
                            Set the Gateway ID to be the first 3 bytes of MAC address + 'FFFE' + last 3 bytes of MAC address
                            PORT = 1700
                            NTP_PERIOD_S = 3600
                            for US915
                            LORA_NODE_DR = 0
