Anyone successfully using Lora.add_channel / remove_channel functions?
  • Hi Guys,
    Unfortunately I don't have a LoRaWAN Gateway with standard 868 bands so I'm trying to use the Lora.add_channel functions to change the LoRaWAN channel frequencies to suit the bands supported but a local provider.
    However I'm still not able to send data to the gateway, so I'm wondering if it's just me/my setup/code and it's working fine for others or are other people also not able to send data if they're also using the Lora.add_channel / remove_channel functions?
    To check the gateway I've verfied that I can send data via a RN2483-PICTail module and a terminal and that works fine after I (rather teadiously rediffined all the channels...
1 out of 1
