    How to get data from a particular device in lopy ?
    lopy4lopy lorawanloralorawan abpcoding
    3 Posts 2 Posters 913 Views 2 Watching
    • H Offline
      Harish kumar
      Hi Everyone !
      I just need to know how to get data from a particular device ? To make clear, I am using Lopy as a repeater.For example, now I am sending data from arduino, and lopy perfectly transmits to the server. But now I have to create a list in lopy with the several device address , so it should only get data from those particular devices. I hope everyone understands me.I will share my code here.
      from network import LoRa
      import binascii
      import struct
          lora = LoRa(mode=LoRa.LORA, region=LoRa.EU868, sf = 7, frequency = 868500000)
          # create a raw LoRa socket
          s.setblocking(True)
          # get any data received...
          data = s.recv(64)
          print(data)
          lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868,  sf = 12)
          dev_addr = struct.unpack(">l", binascii.unhexlify('26010000'))[0]
          nwk_swkey = binascii.unhexlify('9A51C4DD083444A245C0000000000000')
          app_swkey = binascii.unhexlify('7DF13A7CD2B2AA078710000000000000')
          # join a network using ABP (Activation By Personalization)
          # create a LoRa socket
          # set the LoRaWAN data rate
          # make the socket blocking
          # (waits for the data to be sent and for the 2 receive windows to expire)
          s.setblocking(True)
          # send some data
          s.send(data)
          print('data sent')
      Thank you in Advance !
        robert-hh @Harish kumar
        @harish-kumar You cannot restrict your Lopy repeater to receive messages only from certain devices. You have to add any controls at your script level. And be also aware, that at the LoRaWAN server you will all data see as being sent by your repeater.
        • H Offline
          Harish kumar @robert-hh
          @robert-hh Sorry for the late and Thanks for your reply. I have tried with simple change like adding if statement with particular device address but it's not working. Is there any other possible way ?
