    AWS IoT Device Support for LoPy
    25 Posts 10 Posters 12.3k Views 13 Watching
    • R Offline
      RSK
      Will LoPy supports AWS IoT integration using MQTT.
      https://github.com/aws/aws-iot-device-sdk-python/blob/master/README.rst
      AWS IoT SDK contains Paho MQTT Python client library.
      currently umqtt does not support this, Then what is equivalent for Paho MQTT to achieve AWS integration.
      https://github.com/micropython/micropython-lib/tree/master/umqtt.simple
      Thanks & Regards,
      Satish Kumar. R.
      B G 2 Replies Last reply Reply Quote 0
      • B Offline
        Batilan @RSK
        @RSK
        You might want to have a look at this thread. When Daniel follows up we might have a solution :-)
        • V Offline
          vruizvil
          I have tested fine integration with IoT Bluemix Platform from Lopy, using mqtt library.
          https://internetofthings.ibmcloud.com
          • R Offline
            RSK
            Re: AWS IoT Device Support for LoPy
            Good to hear, we are trying to build and integrate with all possible cloud solution like Hive MQ, Bluemix, Azure, AWS etc...
            My requirement to migrate the existing system which uses AWS, have the data pushed to AWS from LoPy.
            @daniel Could you help in getting the experiment code tested for AWS from Micropython umqtt.
            Thanks & Regards,
            Satish Kumar. R.
              daniel
              Dear Satish, sorry for the delay. Please check this example here:
              https://github.com/danicampora/aws_demo
              You need to get the certificate files and the key from Amazon. Place them somewhere inside /flash (via the ftp server) and pass the full paths when wrapping the socket.
              simple.py is the MQTT library with TLS support. You don't need to touch anything there. Just look at main.py to connect to WiFi, and then at demo.py where you need to change the certificate file paths and the AWS connection details.
              Cheers,
              Daniel
              U 1 Reply Last reply Reply Quote 0
              • R Offline
                RSK
                Thanks Daniel !
                Will integrate and check if this works for me.
                • R Offline
                  RSK
                  @daniel Facing issue in connecting LoPy with AWS IoT.
                  Was thinking that problem might be with the cert files generated from AWS IoT.
                  Ensured that they are perfectly fine and working fine with MQTT.fx tool, running the tool in windows 7 32-bit machine. Downloaded from http://mqttfx.jfx4ee.org/index.php/download
                  0_1481883112428_upload-75eb4fca-f2ac-4587-ac94-858e517108ba
                  Published myTopic/1 from AWS and Subscribed the same in MQTT.fx tool, and they works fine. This helps me to ensure that cert files are fine.
                  0_1481883292512_upload-0b378037-9e6d-4512-8e11-8861de9b729b
                  The same cert files are moved to /flash/cert/*, and this time it passes through ssl.wrap_socket() successfully.
                  0_1481883475340_upload-469b1421-25be-4020-b4b1-9c3bf587775d
                  After passing ssl.wrap_socket() the exception occurs in next statement self.sock.connect(self.addr). To confirm this added the connect function in try exception block to get the error type. and it gives OSError.
                  0_1481883780191_upload-d6f53a2e-ff1f-442b-b6b1-fea0be2ebeb9
                  0_1481883850197_upload-ad29e5cc-e6a6-4c2e-88ac-39b8cfcc3942
                  So this shows that error is with socket.connect().
                  Again to cross check used the IP 35.160.47.159 in MQTT.fx tool to connect and it worked fine with the tool.
                  Please help to resolve the issue.
                  Thanks & Regards,
                  Satish Kumar. R.
                  • R Offline
                    RSK
                    @administrators
                    Could someone help in this reg?
                    Thanks & Regards,
                    RSK.
                      daniel
                      @RSK, I would need to know the OSError number that you are getting.
                      What you could also do, is to email me all your source files, the certificates, and give me temporal access to your AWS account so I can test it fully on my end.
                      BTW, are you using static IP configuration on the LoPy/WiPy 2.0? There are known issues around this that we are still trying to resolve with Espressif. If you are, please give your code another try using DHCP instead... Thanks.
                      Cheers,
                      Daniel
                        jomifo Pybytes Beta
                        Hi @daniel, I am also having issues with your aws demo.
                        When I break out of the loop and test the connection manually I get OSError -32512
                        DEVICE_ID = "lopy-gateway"
                        HOST = "[redacted].iot.us-east-2.amazonaws.com"
                        TOPIC_DOWNLOAD = "Download"
                        TOPIC_UPLOAD = "Upload"
                        from simple import MQTTClient
                        connection = MQTTClient(DEVICE_ID, server=HOST, port=8883)
                        connection.connect(ssl=True, certfile='/flash/cert/lopy-gateway.cert.pem', keyfile='/flash/cert/lopy-gateway.private.key', ca_certs='/flash/cert/root-CA.crt')
                        File "simple.py", line 77, in connect
                        OSError: -32512
                        I have tested from my desktop using the Python AWSIoTPythonSDK module from AWS with the same credentials successfully.
                        I could send my code if that would help.
                        Thanks for any insight.
                          jomifo Pybytes Beta
                          @daniel Could you please confirm your AWS IoT demo still works for you?
                          I am using the latest firmware and when trying to connect to the MQTT broker using the REPL, I get OSError 0-
                            File "simple.py", line 79, in connect
                          OSError: 0
                          >>> import os
                          >>> os.uname()
                          (sysname='LoPy', nodename='LoPy', release='1.0.1.b1', version='v1.8.6-265-g5722083 on 2016-12-22', machine='LoPy with ESP32')
                            daniel @jomifo
                            @jomifo I'll be performing some tests this morning and get I'll get back with an update shortly.
                            Cheers,
                            Daniel
                              daniel
                              @jomifo I can confirm that the issue is there, we also get the exception with OSError 0. We'll investigate it and provide and solution on tomorrow's release.
                                jomifo Pybytes Beta
                                @daniel - I tried this in the latest release (1.1.0.b1) and am now getting a different OSError. Just wondering if you were able to address this in the latest release and verify your AWS IoT demo works so I know if it is something on my end. Thanks.
                                >>> HOST = "[redacted]"
                                OSError: -32512
                                >>> import os
                                >>> os.uname()
                                (sysname='LoPy', nodename='LoPy', release='1.1.0.b1', version='v1.8.6-274-g9a2018f on 2016-12-29', machine='LoPy with ESP32')
                                  daniel
                                  @jomifo we are also experiencing that error and it is caused by the changes made to integrate the Bluetooth stack. We are still investigating the exact root cause. Apologies for the the delay.
                                    jomifo Pybytes Beta @daniel
                                    @daniel No problem. Thanks for the quick confirmation reply.
                                      gertjanvanhethof Pybytes Beta
                                        daniel
                                        @gertjanvanhethof no, we are still busy trying to solve it. It's going to have to wait for the next release.
                                        • U Offline
                                          ubiq_01 Pybytes Beta @daniel
                                          Hello Daniel, dear all,
                                          I used your code and could do interaction with a custom mosquitto MQTT broker + Let's encrypt certificate (so using TLS on port 8883 and server authentication) from my WiPy. Still using the older firmware from Dec 16th which works fine with TLS + certificates.
                                          https://twitter.com/_rac01/status/814894297208287237
                                          Many thanks for the great work!
                                          Ralf
                                            @daniel Just checking... this is still an open issue, correct? Thanks.
                                            J 1 Reply Last reply Reply Quote 2
                                            • 1
                                            • 2
                                            • 1 / 2
