    Important update regarding LTE modem updates
    lte
    123 Posts 26 Posters 44.9k Views 32 Watching
      robert-hh @tuftec
      @tuftec said in Important update regarding LTE modem updates:
      I do not see any transmissions in the band 8 uplink frequency area
      Same for me at Band 20. No RF send activity at all.AT least a cell is acquired in Band 20 (commands 'AT!="showphy"' and 'AT+CSQ')
        JoseDLopez
        I just updated to 37781 NB-IoT firmware my GPy. But i just realized that it will only works with Ericsson or Huawei Nodes.
        Here in Chile we only have available one NB-IoT working node and it is Nokia, should it work?
        Best regards,
          danielm @robert-hh
          @robert-hh
          This is the sequence which works for me (method is part of class):
          def test1(self):
          	self.lte = LTE()
          	self.lte.send_at_cmd('AT+CFUN=0')
          	self.lte.send_at_cmd('AT!="clearscanconfig"')
          	self.lte.send_at_cmd('AT!="addscanfreq band=20 dl-earfcn=6190"')
          	self.lte.send_at_cmd('AT!="zsp0:npc 1"')
          	self.lte.send_at_cmd('AT+CGDCONT=1,"IP","nbiot.telekom.sk"')
          	self.lte.send_at_cmd('AT+CFUN=1')
          	pycom.rgbled(0xff0000)
          	while not self.lte.isattached():
          		print('Attaching…')
          		time.sleep(0.25)
          	pycom.rgbled(0x0000ff)
          	self.lte.connect()
          	while not self.lte.isconnected():
          		print('Connecting…')
          		time.sleep(0.25)
          	pycom.rgbled(0x008000)
            tuftec @danielm
            @danielm thanks for that.
            I gather you are not using the latest firmware revisions?
            The zsp0:npc 1 command does not seem to work anymore.
            I have tried something similar, but modified for my local carrier (Vodafone) and just can not get it to attach.
            Nothing seems to get transmitted in the band that I need to select (band 8).
            Peter.
              robert-hh
              @danielm Thanks. But, as @tuftec said above, at least the zsp0::npc command does not exist in the new firmware. I could try with the old firmware, which is now available again.
                danielm
                Pycom FW release on my FiPy is 1.18.1.r1. I used built-in script to upgrade Sequans modem via UART to NB1 firmware version 37781.
                >>> node.lte.send_at_cmd("AT+CGMR")
                '\r\nUE6.0.0.0\r\n\r\nOK\r\n'
                Is there any command for more detailed version information?
                P robert-hhR 2 Replies Last reply Reply Quote 0
                  peterv @danielm
                  @danielm AT!="showver"
                    robert-hh @danielm
                    @danielm
                    AT+CLAC
                    returns a list of all supported AT commands,
                    AT!="help"
                    returns a list of all Sequans specific commands. These are quite a few, like 400. Since the help list is longer than the buffer, you can get sections of it with:
                    AT!="help startIdx=nn qty=nn" e.g.
                    AT!="help startIdx=1 qty = 20" for the first 20 commands.
                    AT!="help help" shows how to use help
                    Interesting is the commands which returns the internal file tree, which is structured like a linux file tree. So maybe the device runs an embedded linux.
                      danielm @peterv
                      @peterv @robert-hh
                      Thanks, will try that tomorrow and verify current Sequans modem firmware version.
                      Any ideas how to achieve reasonable power consumption without eDRX and PSM?
                      I was thinking to put ESP32 to light sleep for 5-10s after sending AT+CFUN=1 and then check if the modem is attached and connected.
                        Jiemde Pybytes Beta
                        Just successfully connect to NB-IoT network Orange in Belgium with a Gpy in about 14 secondes!
                        Now can continue to develop the application! :))
                        T 1 Reply Last reply Reply Quote 1
                          tuftec @Jiemde
                          @jiemde did you have to do anything special?
                          What band are you using? What is your connection command sequence?
                          P J 2 Replies Last reply Reply Quote 1
                            peterv @tuftec
                            @tuftec I posted my command sequence for Orange Belgium in https://forum.pycom.io/topic/3476/orange-belgium-gpy/7
                              danielm
                              @peterv @robert-hh
                              This is Sequans modem version info using "showver" command:
                              FIRMWARE VERSION
                              Bootloader0 : 5.1.1.0 [33080]
                              Bootloader1* : 5.1.1.0 [38638]
                              Bootloader2 : 5.1.1.0 [38638]
                              NV Info : 1.1,0,0
                              Software : 6.0.0.0 [37781] by robot-soft at 2018-07-05 20:21:02
                              UE : 6.0.0.0
                              COMPONENTS
                              ZSP0 : 1.0.99-319
                              ZSP1 : 1.0.99-302
                              Today I will test the conenctivity again to be sure. NB-IoT network coverage is not nation-wide yet (should be until end of 2018) so I will travel to different city to try it. In the meantime I installed my development FiPy board into custom PCB and housing.
                                Jiemde Pybytes Beta @tuftec
                                @tuftec Here is the sequence I've used for connecting the Gpy to the Orange network in Belgium.```
                                from network import LTE
                                lte = LTE()
                                # print("OK line 1")
                                # print("OK line 2")
                                lte.send_at_cmd('AT!="addscanband band=20"')
                                # print("OK line 3")
                                lte.send_at_cmd('AT!="disablelog 1"')
                                # print("OK line 4")
                                lte.send_at_cmd('AT+CGDCONT=1,"IP","nbiot.iot"')
                                # print("OK line 5")
                                # print("OK line 6")
                                while not lte.isattached():
                                	print('Attaching…')
                                	time.sleep(0.25)
                                lte.connect()
                                while not lte.isconnected():
                                	time.sleep(0.25)
                                print("lte is connected")
                                # Print line are just there to verify if the AT command are executed or not
                                  arneme @arneme
                                  @arneme I can confirm that we have managed to connect the FiPy to our guard band NB-IoT Huawei eNodeB based RAN (Telenor Norway). We do however see some strange signalling behaviour when the FiPy tries to connect to the network. It would help if the documentation could be updated (so that we might be able to get the FiPy to behave correct) or if we could get someone in Pycom or Sequans to discuss this with. We are officially launching a country wide NB-IoT (and Cat M1) network in a few weeks so it would be great if we could get this sorted out asap.
                                  X 1 Reply Last reply Reply Quote 1
                                  • X Offline
                                    Xykon administrators @arneme
                                    @arneme As a network operator please email bettina(at)pycom.io as we can provide special hardware & software to allow access to the DCP port.
                                    For everyone else, NB1 firmware 38729 is now available for download at https://software.pycom.io/downloads/sequans2.html with the same updater.elf file as all the other packages.
                                    Christian Ehlers
                                    robert-hhR A 2 Replies Last reply Reply Quote 1
                                      robert-hh @Xykon
                                      @xykon said in Important update regarding LTE modem updates:
                                      @Xykon Do you know what has been changed? And did you succeed in testing this version?
                                      • X Offline
                                        Xykon administrators @robert-hh
                                        @robert-hh All I've been told is that it contains various bug fixes compared to the previous version. I haven't yet had any success with this firmware... I keep getting LWM2M/ audit >| lwm2m: error while getting IP addresses and I'm getting the same message in any firmware and both with Vodafone Netherlands and Amarisoft's NB-IoT software. I've prepared trace logs that I've sent to both Vodafone and Sequans for analysis.
                                        Christian Ehlers
                                        robert-hhR T 2 Replies Last reply Reply Quote 0
                                          robert-hh @Xykon
                                          @xykon There is some difference in behavior to the previous version: it now shows RF activity. It still does not attach, but at least there is some communication.
                                            arneme @Xykon
                                            @xykon OK, I will try again to reach her :-)
                                            • 1
                                            • 2
                                            • 3
                                            • 4
                                            • 5
                                            • 6
                                            • 7
                                            • 3 / 7
