socket.getaddrinfo return false values
I did submit this issue a few weeks ago (rel 0.9.6). But no answer. I hoped it would be fixed in the 0.9.7b1 but the issue is always present :
import socket mysite = 'www.pycom.io' addr = socket.getaddrinfo(mysite, 80) print(mysite,': ',addr) >>> www.pycom.io : [(2, 1, 0, '', ('111.99.107.101', 80))]
sometimes return 0.0.0.0
the good values should be 104.18.45.76 or 104.18.44.76Any idea ?
Problem is in the static parameters of the wlan.ifconfig()
see explanations and fix in post :
ATTENTION: socket.getaddrinfo() resolves to randon false IP Addresses
Just tested with 1.0.0b2 but no change
@livius yes Lopy is connected to Internet through the wifi interface.
done in boot.py with a functional dns server specified in the wlan.ifconfig call.
problem always present in the 1.0.0b1 release.
Info is false but
did you connected your board to Internet?
If yes - how?
