    WIPY & Battery
    wipy 3.0battery
    2 Posts 2 Posters 797 Views 2 Watching
      Tschili
      i have i WIPY3.0 with 3.7v Battery powered on the expboard 3.0.
      When i now remove the battery and plug is back, the wipy not start.
      when i then plug the USB Cable, all works fine.
      after the Wipy works fine, i remove the USB cable, and the wipy still running.
      Why he not start only with the battery
      Thanks for help
        jcaron @Tschili
        @tschili There's a similar issue being discussed here: https://forum.pycom.io/topic/3436/expansion-board-3-0-battery-power-not-enough-juice
        It seems it's related to the Expansion Board 3.0 rather than the WiPy in that case, not sure if it's the same problem you have.
