    nano-gateway bringup
    gatewaylopy4 bringup
    13 Posts 4 Posters 1.6k Views 4 Watching
    • M Offline
      malachib
      I've spent about 2 hours on this now, cannot get gateway to show 'connected' on TTN.
      nanogw.start() produces:
      [ 13423.390] Starting LoRaWAN nano gateway with id: b'30AEA4FFFE783508'
      [ 13424.872] WiFi connected to: fact.home
      [ 13424.876] Syncing time with pool.ntp.org ...
      [ 13425.484] RTC NTP sync complete
      [ 13425.493] Opening UDP socket to us-west.thethings.network (13.66.229.235) port 1700...
      [ 13425.509] Setting up the LoRa radio at 868.1 Mhz using SF7BW125
      [ 13425.520] LoRaWAN nano gateway online
      (/assets/uploads/files/1533180731775-screen-shot-2018-08-01-at-8.30.06-pm-resized.png)
      Probably I'm missing something simple...
        robert-hh @malachib
        @malachib In which region are you located? You have selected the EU868 plan, but an US router. My section of config.py looks like:
        SERVER = 'router.eu.thethings.network'
        PORT = 1700
        NTP = "pool.ntp.org"
        NTP_PERIOD_S = 3600
        • M Offline
          malachib @robert-hh
          @robert-hh I'm in USA but the Lopy folks sent me the wrong gear, so I actually do have 868 parts here in the US (shh, don't tell the FCC)
          bmarkusB 1 Reply Last reply Reply Quote 0
          • bmarkusB Offline
            bmarkus @malachib
            @malachib said in nano-gateway bringup:
            Antenna may be an issue, but device itself is the same for EU868 and US915, just reconfigure it.
            M 1 Reply Last reply Reply Quote 1
            • M Offline
              malachib @bmarkus
              @bmarkus Alright I'll do that. I got an odd error when I set it up for US bands, so I just assumed. I'll post the error if it persists
              EDIT: Here's the error
              (manual bringup)
              lora = LoRa(mode=LoRa.LORAWAN, frequency=903900000)
              ValueError: frequency 903900000 out of range
              (nano gateway bringup)
              [    22.361] Opening UDP socket to us-west.thethings.network (13.66.229.235) port 1700...
              [    22.379] Setting up the LoRa radio at 903.9001 Mhz using SF7BW125
                File "lib/startmal.py", line 19, in <module>
                File "/flash/lib/nanogateway.py", line 167, in start
              I see some folks saying to add region=LoRa.US915 but my LoRa class doesn't have US915 in it
              EDIT2: Upgraded to 1.18.0.r1 and selected US regions. Now everything is configured to 915MHz but initial problem still persists
                robert-hh @malachib
                @malachib Besides antenna (did you plug in the right antenna port for US915? see https://docs.pycom.io/chapter/datasheets/downloads/lopy4-pinout.pdf), your router may suppress UDP packets. When the nanogateway is running, you should see lines like:
                [143209.052] Pull ack
                [143224.058] Push ack
                • M Offline
                  malachib @robert-hh
                  @robert-hh I've plugged in the antenna across from the reset button, near the "p part pf pycom
                  I never see those 'push' or 'pull' messages that you describe
                  I'm running an Apple Airport Express. I'm under the impression UDP packets work OK (VoIP and video games work well) but have not done a conclusive test actually. I presumed the gateway only initiates contact to server, not vice versa, but am getting some indication I may have to setup port forwarding. perhaps?
                  EDIT:
                  I've added port forwarding, but no change. DNS resolution does work from the board, and mDNS works on other equipment on the network so WLAN UDP appears online. I tried tcpdump but I don't quite know how to make it promiscuous enough to capture traffic between LoPy4 and the router....
                  • danD Offline
                    dan
                    Hi @malachib,
                    If I understand correctly, you're running the US config now. Have you changed it in the TTN console as well? (in your initial post, it shows EU)
                    robert-hhR M 2 Replies Last reply Reply Quote 1
                      robert-hh @dan
                      @dan According to my tests, that does not affect the server connectivity. Only donwlink messages would be configured for the wrong frequency plan. But obviously it should be set to the proper region.
                      • M Offline
                        malachib @dan
                        @dan that is correct
                        [    40.615] Starting LoRaWAN nano gateway with id: b'30AEA4FFFE783508'
                        [    40.640] WiFi connected to: fact.home
                        [    40.647] Syncing time with pool.ntp.org ...
                        [    50.104] RTC NTP sync complete
                        [    50.324] Opening UDP socket to us-west.thethings.network (13.66.229.235) port 1700...
                        [    50.340] Setting up the LoRa radio at 903.9001 Mhz using SF7BW125
                        [    50.351] LoRaWAN nano gateway online
                        [    50.357] You may now press ENTER to enter the REPL
                          robert-hh @malachib
                          @malachib If I look into the documentation of TTN and the default json script
                          https://github.com/TheThingsNetwork/gateway-conf/blob/master/US-global_conf.json,
                          I see the following server address: router.us.thethings.network
                          Maybe you try that one in config.py of the nanogateway.
                          • M Offline
                            malachib @robert-hh
                            @robert-hh I'll try that. I got the us-west address directly from the gateway configuration screen FYI
                            • M Offline
                              malachib @robert-hh
                              @robert-hh that did it!
                              router.us.thethings.network was the key! Nowhere do I see that URL on TTN gateway config, so you really saved my bacon there. Thank you!
