    Exp Board 2.0 serial communication problem
    expansion boardcom portftdi
    45 Posts 3 Posters 8.7k Views 3 Watching
      robert-hh @szyba91
      @szyba91 Please follow the instructions from the documentation: https://docs.pycom.io/chapter/gettingstarted/programming/FTP.html
        szyba91 @robert-hh
        @robert-hh Looks like i had to reset program Filezilla. Now I'm finlly connted via FTP.
        Could you explain me how to upload the code via FTP ?
          robert-hh @szyba91
          @szyba91 You can drag files between the two panes. Just maneuver on the left pane to your project directory and move files to the right side. Source files can be placed in /flash or /flash/lib, to be found by the import statement. Within the filezilla settings, section "modify files" (or so) you can define your favorite editor. If then in a file pane, right click, you chose view/edit, you can directly edit the file.
          Edit: it is important that in the setting you have set passive mode/1 connection only. It is also convenient to add your device to the server list under file->server manager
          Edit2: You can create bookmarks in Filezilla, which include directory settings and device connections.
          Edit 3: If you are by chance a Firefox user, you might like FireFTP as ftp client, which in my opinion is easier to use than FileZilla. There is no similar too for Google Chrome.
            szyba91 @robert-hh
            @robert-hh said in Exp Board 2.0 serial communication problem:
            OK.I've dragged files form computer(defult left window) to flah -> lib (default right side).
            First I've do so with simple RGB led and it works and i was also able to see REPL prompt .
            I thought myself "yes finally I go further with IoT project". So - again I uploded simple LoRa raw ping code between A and B device and.... doesn't work :(
            Maybe i will create another subject? This one is actaully solvde becasue with Your help i was able to fix communication problem - now it seams that this is different kid of problem.
              robert-hh @szyba91
              @szyba91 What do you mean with: does not work? The copying or the script?
              For copying Filezilla also support a upload option with the right cick on the file. SImple Double-Click also copies. Did you set the number of transfers to 1 in the settings? The ftp server in the xxPy devices is pretty limited.
              I had never problems using ftp for file transfer, but I'm using FireFTP, which is a Firefox plugin. That is convenient because I have firefox open anyhow almost all the time.
              • 1
              • 2
              • 3
              • 3 / 3
