    Using SPI on SyPy
    spisypy
    6 Posts 2 Posters 918 Views 2 Watching
      alidaf
      I just can't seem to get SPI working on the SyPy. I am trying to use I2C as well but due to the conflicting pins, I have shifted the I2C pins to P8 and P9 and it works fine.
      For CS I have tried P12 and P23. Using P12 causes problems when uploading code probably because it keeps the pin high, which causes a firmware downgrade. Pins 13-18 are input only so can't be used. Pins 5-7 are SPI but connected to the Sigfox module. I don't think I can use pins 0-4 either so it doesn't leave much room for manoeuvre.
      I am using the default pins for CLK, MOSI and MISO, i.e. 10, 11 & 14.
      Is there some other connectivity that I am missing?
        robert-hh @alidaf
        @alidaf Pins 10,11,14 should work. Pin 14 has no internal pull-up, so you have to supply an external one.
          alidaf @robert-hh
          @robert-hh I've moved MISO to pin 21 but still no joy.
            alidaf
            I am testing with the following code:
            from machine import Pin
            from machine import SPI
            #import binascii
            #SPI  pins.
            SPI_CS   = 'P23'
            SPI_MOSI = 'P11'
            SPI_MISO = 'P22'
            SPI_CLK  = 'P10'
            REGISTER_TEST      = 0x00
            REGISTER_WRITE_BIT = 0x80
            REGISTER_READ_MASK = 0x7f
            SPI_LOW  = 0
            SPI_HIGH = 1
            spi_cs = Pin(SPI_CS, mode = Pin.OUT)
            spi_cs.value(SPI_HIGH)
            spi = SPI(0, mode=SPI.MASTER, baudrate=1000000, pins=(SPI_CLK, SPI_MOSI, SPI_MISO))
            # Test register should return whatever value is written to it.
            for data in range(0, 0x7e):
                spi_cs.value(SPI_LOW)
                print("Writing 0x{:02x} to register 0x{:02x}".format(data, REGISTER_TEST))
                wbuf = bytes([REGISTER_TEST | REGISTER_WRITE_BIT, data])
                # Write data into register.
                spi.write(wbuf)
                # Read data from register.
                #spi.write(bytes([REGISTER_TEST & REGISTER_READ_MASK]))
                #rbuf=spi.read(1)
                tbuf = bytes([REGISTER_TEST & REGISTER_READ_MASK])
                rbuf = spi.read(1, write=tbuf[0])
                #numRead = spi.readinto(rbuf, write=tbuf[0])
                print("Read 0x{:02x} from register 0x{:02x}".format(rbuf[0], REGISTER_TEST))
              robert-hh @alidaf
              @alidaf Strange. Dou you have a means of testing the communication, like a logic analyzer (Saleae clone?)
                alidaf @robert-hh
                @robert-hh Unfortunately not although I have converted the code to Arduino C++ and used it on an Adafruit Feather with no problem.
