    UART: I cannot get any reading from GPS
    gpyuartexpansion boardgps
    4 Posts 2 Posters 730 Views 2 Watching
      andrejpekarcik
      I connected GPS module to GPy and tried to read some data from it using UART. No success despite many attempts. Reading is always None. GPS module works perfectly as I have connected it to my computer and sends data.
      from machine import UART
      uart = UART(1, 9600)
      uart.init(9600, bits=8, parity=None, stop=1, pins=('P3','P4'))
      print (uart.readline())
          if (uart.any()>0):
                  print ('Yra')
      Any help appreciated!
      Used items:
      Exp. board 3.0
      (sysname='GPy', nodename='GPy', release='1.18.0.r1', version='v1.8.6-849-9569a73 on 2018-07-20', machine='GPy with ESP32', pybytes='0.9.0')
      GPS: GP-20U7
        robert-hh @andrejpekarcik
        @andrejpekarcik how about swapping P3 and P4, either the wires or the arguments?
            if (uart.any()>0):
        or better:
        import sys
        uart.init(9600, bits=8, parity=None, stop=1, pins=('P3','P4'), timeout_chars = 10)
            if (uart.any()>0):
                sys.stdout.write(uart.read().decode())
        A 1 Reply Last reply Reply Quote 1
          andrejpekarcik
          I tried your code, same result.
          How can I test somehow if UART on GPy is working?
            andrejpekarcik @robert-hh
            @robert-hh
            Hooray! I've got it!
            Signal wire was broken between pin and GPS. Thanks.
