    LoPy Cannot Change DR or SF in LoRaWAN mode (always SF10, dr 0, bw 125kHz)
    data ratespreading factolopy lorawanadr
    4 Posts 3 Posters 692 Views 3 Watching
    • B Offline
      brady.aiello
      I'm having a lot of difficulty manually setting the data rate and spread factor with the LoPy. I'm wondering if anyone has been able to manually set dr and sf in LoRaWAN mode? I'm doing this:
      lora = LoRa(mode=LoRa.LORAWAN, sf=7, region=LoRa.US915)
      for i in range(72):
          if 0 <= i < 8:
              print(curr)
              lora.add_channel(index=i, frequency=curr, dr_min=3, dr_max=3)
              curr += f_inc
              lora.remove_channel(i)
      lora.join(activation=LoRa.ABP, auth=(dev_addr, nwk_skey, app_skey))
      What happens is that the first 7 messages won't even be detected by the gateway. The 8th message uses sf 10 on 905.1. If I set this value on the socket itself, with
      s.setsockopt(socket.SOL_LORA, socket.SO_DR, 3)
      nothing is ever picked up by the gateway. BTW, I'm using TTN's US frequencies. Thanks.
        jcaron @brady.aiello
        @brady-aiello what gateway are you using, and what frequencies is it listening on?
        • B Offline
          brady.aiello @jcaron
          @jcaron The Rising HF RHF301, on the frequencies described here:
          https://account.thethingsnetwork.org/api/v2/frequency-plans/US_902_928
          So, it looks like that's
          903900000
          904100000
          904300000
          904500000
          904700000
          904900000
          905100000
          905300000
          all on 125 kHz bw.
            robert-hh @brady.aiello
