    machine.deepsleep does not 'reset'
    deep sleeptimesleep
    2 Posts 2 Posters 626 Views 2 Watching
    • philwilkinsonP Offline
      philwilkinson
      I am encountering a problem using machine.deepsleep() using a LoPy4 on an expansion board 3.0.
      The code counts pin interrupts and periodically publishes the total count. The code maximises deepsleep.
      The sensor count uses Pin_deepsleep_wakeup and the total time interval between publish uses machine.deepsleep()
      The code all works fine until the time config.interval is complete and wake_reason == 1.
      After the LoRa_publish is called the final line of code machine.deepsleep(config.interval) does not 'reset' the deepsleep time. On entering deepsleep the LoPy immediately returns 'timer completed' indicating that the time interval passed into deepsleep() method is not the config.interval figure.
      Any ideas??? Do I have to clear some memory before I call machine.deepsleep() again ???
      import utime
      from machine import Timer
      import config #user defined
      import LoRa_publish #user defined
      rst=machine.reset_cause()
      if rst != 3: # if not woken from deepsleep
          utime.sleep(10) #to allow ctrl+C
          pycom.nvs_set('counter', 0)
          machine.pin_deepsleep_wakeup(pins = ['P23'], mode = machine.WAKEUP_ALL_LOW, enable_pull = True)
          if (machine.wake_reason()[0])==1: #pin wakeup
              total_count = pycom.nvs_get('counter') +1
              pycom.nvs_set('counter', total_count)
              print(machine.remaining_sleep_time())
              machine.deepsleep(machine.remaining_sleep_time())
          elif (machine.wake_reason()[0])==2: #RTC timer complete
              print('timer completed')
              LoRa_publish.publish(total_count) #int published to TTN
              machine.deepsleep(config.interval) #this does not restart a new interval
      • V Offline
        Vinicius Pinhatari campos
        Have you fix it?
        I'm facing the same problem
