    Lopy4 to Lopy4 with BLE get_adv() always none [Solved]
    lopy4ble
    3 Posts 2 Posters 656 Views 2 Watching
      Amarulp
      Hello everyone!
      I was trying to connect two Lopy4 with BLE, but bluetooth.get_adv() is always returning none. Just in a few cases it and using the same code work but then stopped.
      import ubinascii
      from network import Bluetooth
      from time import sleep
      bt = Bluetooth()
      bt.init()
      bt.set_advertisement(name="lopy", manufacturer_data="lopy_v1")
      if bt.isscanning():
          bt.stop_scan()
      bt.start_scan(-1)
      while bt.isscanning():
          adv = bt.get_adv()
          if adv:
              print(adv)
      Both with the same code, and different names (I also try it with the same name)
      Thank you
      • E Offline
        Eric73 @Amarulp
        @amarulp Hello, I think you cannot, at same time, advertise and scan for device with a lopy but you can test it in case, with some luck it can work.
        I suggest you to have on one lopy to advertise (btw you must add in your code bt.advertise(true) after your bt.set_advertisement according to documentation) and the other lopy do bluetooth scanning.
        A 1 Reply Last reply Reply Quote 1
          Amarulp @Eric73
          @eric73
          Thank you so much!
          It worked! Also, it can scan and advertise at the same time.
