    Data acquisition from WiPy in real time
    wipy2saving dataesp32realtimememoryerror
    5 Posts 2 Posters 835 Views 2 Watching
    • V Offline
      VFlorio94
      Hi, I'm using WiPy 2.0 with an IMU ( BNO055).
      I need to acquire and save my data in real time from TWO IMU. I use a list and at the end of acquisition I save data in a file.txt in the sd card.
      fileIMU1 = open('/sd/dati_IMU1.txt', 'w')
      list_eul = [ ]
      temp = Timer.Chrono()
      temp.start()
      while 1:
              t = temp.read()
              if  t <= sec :
                  gc.collect()
                  list_eul.append(lib_imu.get_euler_int()
                  fileIMU1.write(repr(temp.read()) + '\t')
                  time.sleep(0.2)
                  fileIMU1.write( '\n' + repr(list_eul) + '\t')
                  fileIMU1.close()
                  del list_eul
             break
      Now data were collected in RAM and so I have an issue of 'Memory allocation' because time of acquisition is long (from 10 s to 60 s).
      Another big problem is that if I use two IMU it don't work at sample rate of 0.2 s but it change and it is about 0.4s. How can I impose a sample of 0.2 s with two IMU ?
      How can I do this in another way?
      Is it better reciving data in real time directly on my pc and then save it in a file?
      • M Offline
        Martinnn @VFlorio94
        @vflorio94 said in Data acquisition from WiPy in real time:
        Maybe check the interface library. The pysense libraries for example contained some unnecessarily long waits. Check the datasheet.
        V 1 Reply Last reply Reply Quote 0
        • V Offline
          VFlorio94 @Martinnn
          @martinnn I don't use any interface library
          • M Offline
            Martinnn @VFlorio94
            @vflorio94
            Well, where is lib_imu.get_euler_int() coming from?
            Also, where do the 0.4 s come from? Did you do mesurements which part of the code takes how long?
            • V Offline
              VFlorio94 @Martinnn
              @martinnn lib_imu is a library that I wrote and in this function give only data from IMU and there aren't any delay.
              if I wrote data immediately on a file.txt in SD card it employ 0,2 s so the sample became 0,4.
              but if I collect data and insert them in a list to save data at the end of acquisition it gives me the error 'Memory allocation'.
