    Usage of LoRa antennas
    lopy4lora antenna
    3 Posts 2 Posters 507 Views 3 Watching
    • E Offline
      esatus
      Hi there,
      Is it possible to use both LoRa antennas of LoPy 4 at the same time? We are curious, if we can use 868 MHz while already using the 433 MHz antenna, but we won't test it because we're afraid to damage the LoPy 4, if this won't work.
      Can anybody answer this or has already tested?
      Thanks in advance.
        robert-hh @esatus
        @esatus You can connect both antennas, but you cannot use them at the same time, because the LoRa chip is only using one Antenna at a time.
        • E Offline
          esatus
          That's exactly what I wanted to know. Thanks a lot @robert-hh
