    dfu-util: Cannot claim interface 0
    expansion boardfirmware
    2 Posts 1 Posters 979 Views 1 Watching
      janj
      I'm trying to update my firmware on my Pycom Expansion board V3.0.
      I'm running Fedora 28.
      When following instructions acording to https://docs.pycom.io/pytrackpysense/installation/firmware
      To enter update mode follow these steps:
      Unplug the device
      Press the button and keep it held (on the Expansion Board the S1 button)
      Plug in the USB cable to the host computer and wait 1 second before releasing the button
      After this you will have approximately 7 seconds to run the DFU-util tool
      macOS and Linux:
      $ dfu-util -D pytrack_0.0.8.dfu
      You might need to run dfu-util as sudo. In that case, you will need to enter your password.
      own output:
      sudo dfu-util -D expansion3_0.0.9.dfu
      dfu-util 0.9
      Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
      Copyright 2010-2016 Tormod Volden and Stefan Schmidt
      This program is Free Software and has ABSOLUTELY NO WARRANTY
      Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
      Match vendor ID from file: 04d8
      Match product ID from file: ef99
      Opening DFU capable USB device...
      ID 04d8:ef99
      Run-time device DFU version 0100
      Claiming USB DFU Runtime Interface...
      Google didn't help me so far.
        janj
        Solved. My mistake. I just connected to the expansion board, without the WiPy module on top of it. Then it had the error.
        With the WiPy module connected to the Expansion board, and following the instructions, the firmware update went fine.
