"Run" and "Upload" buttons gone after deep sleep wake up in Atom
I'm using PyMakr (1.4.2) in Atom (1.30.0) and am having problems with some disappearing buttons after a deep sleep wake up.
Normally device (Pytrack with WiPy3) connects to Atom no problem and I see all the buttons:
When I run this code:
from pytrack import Pytrack py = Pytrack() py.setup_sleep(1) #sleep for 1s py.go_to_sleep()
and reconnect my device then the buttons bar looks like this:
If I close Atom and reopen it then the buttons reappear as per usual. It's pretty annoying to have to close and reopen the program every time I run a test though...Does anyone know why the important buttons disappeared and how to make them come back?
Note: this only happens when I use
py.go_to_sleep()
not when I usemachine.deepsleep(1)
Yup, still the same lack of buttons after disconnect/reconnect
@alexpul What happens if you disconnect/reconnect? Still the same?
