LTE NB-IoT firmware: NB-IoT standalone mode support
It is stated:
At the moment the NB-IoT firmware supplied by Sequans only support Ericsson base stations configured for In-Band mode. Standalone and guard-band modes will be supported in a later release. Support for Huawei base stations is also limited and only lab testing with Huawei eNodeB is recommended at the moment. Full support for Huawei is planned for early Q2 2018.Q2 2018 is already in the past.
Is the Standalone mode for NB-IoT is supported? If no - could you please update with expected date to have the mode supported?Thanks
@abrilevskiy We have an NB-IoT network in guardband with Huawei eNodeB. The revision 37781 of the modem firmware at least works on our network. So: the statement you are referring to is no longer correct. Pycom should update the documentation :-)
@arneme what band is your solution deployed?
@tuftec Band 20
