    LTE Available Towers
    gpyltegps
    5 Posts 2 Posters 827 Views 3 Watching
      panda
      Does anyone have an example of how to query available LTE towers (cellid etc) with the Sequans modem? Ultimately I want to try and use the Google location API with this information to locate the GPy.
        robert-hh @panda
        @panda You can try the command:
        lte.send_at_command('AT!="RRC:showDetectedCell"')
        you might repeat that a few times, and it will show you detected cells.
        Also useful might be:
        lte.send_at_command('AT!="RRC:showSiConfig"')
        lte.send_at_command('AT!="RRC:showPlmn"')
          panda
          Thanks! I'll give that a shot.
            panda
            The showDetectedCell command indicates permissions are required when it is executed. How do you get that command to work?
              robert-hh @panda
              @panda With the command:
              lte.send_at_command('AT!="setDbgPerm full"')
              There is also :
              lte.send_at_command('AT!="Help"')
              which gives you the command list, and
              lte.send_at_command('AT!="help <command>"')
              e.g.
              lte.send_at_command('AT!="help help"')
              telling you, how to use help to get the list section by section. The list is quite long.
