    Pytrack GPS library
    pytrackgpslibrarygps pytrack
    11 Posts 3 Posters 1.7k Views 3 Watching
      tttadam
      Hi there!
      Can you recommend me a library for pytrack?
      What's in the documentation is very basic.
      It would be nice to get information some additional information like, time, altitude, speed, Visible satelites, etc?
      What library did you used and what was the project?
      (I am working on a weather ballon)
      Thanks! :)
        jcaron @tttadam
        @tttadam
        You may want to get a look at:
        • https://github.com/inmcm/micropyGPS
        • https://github.com/andrethemac/L76GLNSV4/blob/master/L76GNSV4.py
        Note that both are linked to in the Pytrack examples page.
        T 1 Reply Last reply Reply Quote 1
          tttadam @jcaron
          @jcaron Yes you are right, I wasn't profound enough.
          micropyGPS looks really powerful. However, It's not clear for me how to use it.
          Because this library for uart, but pytrack use I2c am I missing something?
          Is there a sample code where I can start? micropyGPS use predifined gps sentences.
          Thanks in advance.
            jcaron @tttadam
            @tttadam micropyGPS does not handle the I/O, it's up to you to feed it the data using the update function.
            You'll find an example here: https://github.com/gregcope/L76micropyGPS
            The core of it is really just:
                    # get some NMEA data
                    someNmeaData = str(self.i2c.readfrom(GPS_I2CADDR, 128))
                    # Pass NMEA data to micropyGPS object
                    for x in someNmeaData:
                        self.my_gps.update(str(x))
                    time.sleep(0.25)
              tttadam @jcaron
              @jcaron Thank you.
                tttadam
                I am having some issues with L76micropyGPS.py library, if I want to use the I2C.
                When I create an I2C object in the main.py
                i2c=I2C(0, I2C.MASTER)
                I got an OSError: I2C bus error in L76micropyGPS.py at line 54.
                I think it because me and the library both want to use I2C. But I would like to work with a temperature sensor wich communicates in I2C, and later I would like to chain other envirement sensors (as far as I know I can use multiple external sensor on the same pins. )
                  jcaron @tttadam
                  @tttadam unless you provide the full code you are using and full details of what is connected where there’s very little chance anybody is going to be able to help you.
                    tttadam @jcaron
                    @jcaron Fair enough, sorry. :)
                    This is how my boot.py looks like,
                    the GPS set up is from line 50 to 60. This part is run alright, expect some rare cases minor issues with the rtc setup:
                    # # this runs first
                    # #TODO: CLEAN IT up, SD Class(inprogress),
                    import os
                    import math
                    from machine import SD, Pin, UART
                    from pytrack import Pytrack
                    import utime
                    import _thread
                    import gc
                    from L76micropyGPS import L76micropyGPS
                    from micropyGPS import MicropyGPS
                    #my classes
                    from  rgbsignal import RGBSignal
                    from sdlogger import SDLogger
                    uart = UART(0, baudrate=115200)
                    os.dupterm(uart)
                    #TODO:test it, 	outsource it
                    runcount = pycom.nvs_get('runcount')
                    print("The current value of the run counter is: "+str(runcount))
                    pycom.nvs_set('runcount', runcount+1)
                    # this is the led notification class
                    fb = RGBSignal()
                    #the main file will be called
                    machine.main('main.py')
                    #buttonpin = Pin('G17', mode= Pin.IN, pull=Pin.PULL_UP) #button pin on expansion board
                    buttonpin = Pin('G4', mode= Pin.IN, pull=Pin.PULL_UP) #button pin on pytrack board
                    start = True
                    print("Push the button for start booting")
                    #def message(self, color="cyan", interval=0.5, iteration=3):
                    _thread.start_new_thread(fb.message, ["cyan",0.1,0.3])
                    while start:
                        utime.sleep_ms(10)
                        if buttonpin() == 0:
                            start = False
                    _thread.start_new_thread(fb.startup, [])
                    print("Boot file process is started.")
                    gc.enable()
                    print("GC is enabled")
                    print("Free Mem: {}".format(gc.mem_free()))
                    #Setting up the gps:
                    py = Pytrack()
                    my_gps = MicropyGPS(local_offset=1,location_formatting='dd')
                    L76micropyGPS = L76micropyGPS(my_gps, py)
                    gpsThread = L76micropyGPS.startGPSThread()
                    print("Waiting for gps signal")
                    counter = 0
                    while (my_gps.timestamp == (0, 0, 0)):
                        print("Waiting for gps signal: "+str(counter)+" "+str(my_gps.date)+" "+str(my_gps.timestamp))
                        counter +=1
                        time.sleep(2)
                    time.sleep(4)
                    print("Date: "+str(my_gps.date))
                    print("GPS signal is found")
                    print("Time: "+str(my_gps.timestamp))
                    time.sleep(2)
                    print(my_gps.date[0])
                    print(my_gps.date[1])
                    print(my_gps.date[2])
                    print("Setting up the RTC")
                    rtc = machine.RTC()
                    print("RTC before init: {}".format(rtc.now()))
                    dateYear = int(str(20) + str(my_gps.date[2]))
                    rtc.init((dateYear, my_gps.date[1], my_gps.date[0], my_gps.timestamp[0], my_gps.timestamp[1], int(my_gps.timestamp[2]), 0, 0)) #seting up the rtc
                    print("RTC is set : {}".format(rtc.now()))
                    #Create logstructure after GPS initalizaed
                    dataLogger = SDLogger(uart)
                    dataLogger.sdFormat()
                    foldername = str("Flight_"+
                                 str(runcount)+"_"+
                                 str(dateYear)+"-"+
                                 str(my_gps.date[1])+"-"+
                                 str(my_gps.date[0])+"_"+
                                 str(my_gps.timestamp[0])+"-"+
                                 str(my_gps.timestamp[1])+"-"+
                                 str(int(my_gps.timestamp[2])))
                    dataLogger.createFolder(foldername)
                    logfilename = str("LogOfRun"+"_"+
                              str(runcount)+"_"+
                              str(dateYear)+"-"+
                    logheader = "TimeStamp;GPSTimeStamp;Sensor;Value;Location"
                    dataLogger.creatLogFile(logheader,logfilename)
                    # #TODO: Create separate log for sytemlog, telemetry, and sensor data
                    After the boot.py main.py is next, This fails at line 30, when I create the I2C object. With an OSError: I2C bus error in L76micropyGPS.py at line 54.
                    from machine import I2C, Pin, UART
                    from SI7021 import SI7021
                    import gc
                    import _thread
                    #my classes
                    start = True
                    _thread.start_new_thread(fb.message, ["yellow",0.1,3])
                    print("Push the button for start main")
                    while start:
                        time.sleep_ms(10)
                            start = False
                    print("Main has started")
                    print(i2c.scan())
                      tttadam
                        tttadam
                        I found the issue.
                        I gave my I2C object an ID = 1, and that solved the issue.
                          gregcope @tttadam
                          @tttadam Hi. Looks like you might have found my L76micropyGPS.py useful. Any feedback welcome! I just updated the doco as the issue has been resolved, and I had not updated the README.
