    FFI Lib module not found
    moduleslibmicropython
    3 Posts 2 Posters 697 Views 2 Watching
      svonbentzel
      Hi, I'm looking for a library.
      for an i2c script I need the module:
      import fcntl # used to access I2C parameters like addresses
      I found this module. but missing if I want to load this ffi
      it always comes the error message the module ffi can not be found.
      I have already installed ffilib. but without success.
      import uio # used to create file streams
      import time # used for sleep delay and timestamps
      import string # helps parse strings
      File "<stdin>", line 2, in <module>
      ImportError: no module named 'ffi'
        robert-hh @svonbentzel
        @svonbentzel ffi is only need on a PC as link between the Python modules and C-lib code. For python scripts on a Pycom module, this is not available and not required. You have to adapt you initial scripts to deal directly with the PyCom hardware, using e.g. the machine.I2C lib for I2C.
          svonbentzel
          Thank you for the answer. I want to adapt this raspberrypi script to my Pycom WiPy. but I stuck ... :-(
          #!/usr/bin/python
          import io         # used to create file streams
          class AtlasI2C:
          	long_timeout = 1.5         	# the timeout needed to query readings and calibrations
          	short_timeout = .5         	# timeout for regular commands
          	default_bus = 1         	# the default bus for I2C on the newer Raspberry Pis, certain older boards use bus 0
          	default_address = 98     	# the default address for the sensor
          	current_addr = default_address
          	def __init__(self, address=default_address, bus=default_bus):
          		# open two file streams, one for reading and one for writing
          		# the specific I2C channel is selected with bus
          		# it is usually 1, except for older revisions where its 0
          		# wb and rb indicate binary read and write
          		self.file_read = io.open("/dev/i2c-"+str(bus), "rb", buffering=0)
          		self.file_write = io.open("/dev/i2c-"+str(bus), "wb", buffering=0)
          		# initializes I2C to either a user specified or default address
          		self.set_i2c_address(address)
          	def set_i2c_address(self, addr):
          		# set the I2C communications to the slave specified by the address
          		# The commands for I2C dev using the ioctl functions are specified in
          		# the i2c-dev.h file from i2c-tools
          		I2C_SLAVE = 0x703
          		fcntl.ioctl(self.file_read, I2C_SLAVE, addr)
          		fcntl.ioctl(self.file_write, I2C_SLAVE, addr)
          		self.current_addr = addr
          	def write(self, cmd):
          		# appends the null character and sends the string over I2C
          		cmd += "\00"
          		self.file_write.write(cmd)
          	def read(self, num_of_bytes=31):
          		# reads a specified number of bytes from I2C, then parses and displays the result
          		res = self.file_read.read(num_of_bytes)         # read from the board
          		response = filter(lambda x: x != '\x00', res)     # remove the null characters to get the response
          		if ord(response[0]) == 1:             # if the response isn't an error
          			# change MSB to 0 for all received characters except the first and get a list of characters
          			char_list = map(lambda x: chr(ord(x) & ~0x80), list(response[1:]))
          			# NOTE: having to change the MSB to 0 is a glitch in the raspberry pi, and you shouldn't have to do this!
          			return "Command succeeded " + ''.join(char_list)     # convert the char list to a string and returns it
          			return "Error " + str(ord(response[0]))
          	def query(self, string):
          		# write a command to the board, wait the correct timeout, and read the response
          		self.write(string)
          		# the read and calibration commands require a longer timeout
          		if((string.upper().startswith("R")) or
          			(string.upper().startswith("CAL"))):
          			time.sleep(self.long_timeout)
          		elif string.upper().startswith("SLEEP"):
          			return "sleep mode"
          			time.sleep(self.short_timeout)
          		return self.read()
          	def close(self):
          		self.file_read.close()
          		self.file_write.close()
          	def list_i2c_devices(self):
          		prev_addr = self.current_addr # save the current address so we can restore it after
          		i2c_devices = []
          		for i in range (0,128):
          			try:
          				self.set_i2c_address(i)
          				self.read()
          				i2c_devices.append(i)
          			except IOError:
          				pass
          		self.set_i2c_address(prev_addr) # restore the address we were using
          		return i2c_devices
          def main():
          	device = AtlasI2C() 	# creates the I2C port object, specify the address or bus if necessary
          	print(">> Atlas Scientific sample code")
          	print(">> Any commands entered are passed to the board via I2C except:")
          	print(">>   List_addr lists the available I2C addresses.")
          	print(">>   Address,xx changes the I2C address the Raspberry Pi communicates with.")
          	print(">>   Poll,xx.x command continuously polls the board every xx.x seconds")
          	print(" where xx.x is longer than the %0.2f second timeout." % AtlasI2C.long_timeout)
          	print(">> Pressing ctrl-c will stop the polling")
          	# main loop
          		input = raw_input("Enter command: ")
          		if input.upper().startswith("LIST_ADDR"):
          			devices = device.list_i2c_devices()
          			for i in range(len (devices)):
          				print devices[i]
          		# address command lets you change which address the Raspberry Pi will poll
          		elif input.upper().startswith("ADDRESS"):
          			addr = int(string.split(input, ',')[1])
          			device.set_i2c_address(addr)
          			print("I2C address set to " + str(addr))
          		# continuous polling command automatically polls the board
          		elif input.upper().startswith("POLL"):
          			delaytime = float(string.split(input, ',')[1])
          			# check for polling time being too short, change it to the minimum timeout if too short
          			if delaytime < AtlasI2C.long_timeout:
          				print("Polling time is shorter than timeout, setting polling time to %0.2f" % AtlasI2C.long_timeout)
          				delaytime = AtlasI2C.long_timeout
          			# get the information of the board you're polling
          			info = string.split(device.query("I"), ",")[1]
          			print("Polling %s sensor every %0.2f seconds, press ctrl-c to stop polling" % (info, delaytime))
          			try:
          					print(device.query("R"))
          					time.sleep(delaytime - AtlasI2C.long_timeout)
          			except KeyboardInterrupt: 		# catches the ctrl-c command, which breaks the loop above
          				print("Continuous polling stopped")
          		# if not a special keyword, pass commands straight to board
          			if len(input) == 0:
          				print "Please input valid command."
          				try:
          					print(device.query(input))
          				except IOError:
          					print("Query failed \n - Address may be invalid, use List_addr command to see available addresses")
          if __name__ == '__main__':
          	main()
