    joining OTAA on specific channels
    lopy4
    3 Posts 3 Posters 533 Views 3 Watching
      abhishek2101
      Hi
      I want to join OTAA over specific channels and then send data again on some other specific channels, how can I achieve this ?
      • E Offline
        Eric73 @abhishek2101
        @abhishek2101 it's depend in which region you work.
        If it's EU868 documentation say to use
        lora.add_channel(index=0, frequency=868000000, dr_min=5, dr_max=6)
        lora.add_channel(index=1, frequency=868000000, dr_min=5, dr_max=6)
        lora.add_channel(index=2, frequency=868000000, dr_min=5, dr_max=6)
        and join will use 868000000 for TX and RX1 (RX2 is always same frequency in lorawan)
        You cannot choice the channel used by the stack but as the 3 mandatory channel are in same freq....
        bmarkusB 1 Reply Last reply Reply Quote 0
        • bmarkusB Offline
          bmarkus @Eric73
          @eric73 said in joining OTAA on specific channels:
          Not it is just an example, in practice there are no such channel used as 868.0 MHz!
