    method overloading in micropython
    micropythonrgbledoopmethodoverload
    3 Posts 2 Posters 682 Views 2 Watching
      tttadam
      As far as I know there is know method overloading in python or micropython
      Whats the best practice workaround for that?
      I created class for the rgbled. I want to use that for notify me about statuses, and progresses.
      It would be nice to run these notification on second thread, because it's operate with sleeps, and don't want to sleep the whole system for blinking an led.
      BTW, any feedback for my code is welcome ! :)
      My code:
          ######## avaible colors ##########
              # 0xFF3300 - narancs - orange
              # 0xFF0000 - piros - red
              # 0x0000FF - kék - blue
              # 0xEE00FF - lila - purple
              # 0xFFFFFF - fehér - white
              # 0xFF0088 - rózsaszín - pink
              # 0x00FF00 - zöld - green
              # 0x00FFFF - cián - cyan
              # 0xFFBB00 - sárga - yellow
          ######## avaible methods ##########
      		# longsignal(self)
      		# longsignal(self, color)
      		# criticalError(self)
      		# message(self, color)
      		# message(self, color, time)
      		# message(self, color, time, iteration)
      		# okay(self)
      		# startup(self)
      		# shutdown(self)
      		# SOS(self, color)
      class RGBSignal:
          colors = {
              'orange' : 0xFF3300,
              'red' : 0xFF0000,
              'blue' : 0x0000FF,
              'purple' : 0xEE00FF,
              'white' : 0xFFFFFF,
              'pink' : 0xFF0088,
              'green' : 0x00FF00,
              'cyan' : 0x00FFFF,
              'yellow' : 0xFFBB00,
              'off': 0x000000
          def  __init__(self): #this is how a ctor look like
          def startup(self):
      		for k in self.colors:
      			pycom.rgbled(self.colors[k])
      			time.sleep(0.1)
      			pycom.rgbled(self.colors['off'])
      			time.sleep(0.1)
          def longsignal(self):
              pycom.rgbled(self.colors['white'])
          def longsignal(self, color):
              pycom.rgbled(self.colors[color])
          def criticalError(self):
              for x in range(50):
                  pycom.rgbled(self.colors['red'])
                  time.sleep(0.05)
                  time.sleep(0.05)
          def message(self, color, time, iteration):
              for x in range(iteration):
                  time.sleep(time)
                  time.sleep(time)
          def message(self, color):
                  time.sleep(0.5)
          def message(self, color, time):
                  time.sleep(time)
          def okay(self):
                  pycom.rgbled(self.colors['green'])
                  time.sleep(0.6)
          def SOS(self, color):
              time.sleep(0.1)
              time.sleep(0.1)
              time.sleep(0.1)
              time.sleep(0.1)
              time.sleep(0.1)
              time.sleep(0.1)
              time.sleep(0.2)
              time.sleep(0.2)
              time.sleep(0.2)
              time.sleep(0.2)
              time.sleep(0.2)
              time.sleep(0.2)
              time.sleep(0.1)
              time.sleep(0.1)
              time.sleep(0.1)
              time.sleep(0.1)
              time.sleep(0.1)
              time.sleep(0.1)
          def shutdown(self):
              for x in range(10):
                  time.sleep(0.1)
                  time.sleep(0.1)
                  time.sleep(0.1)
        campbellsinclair
        Use default values for arguments.
        def message(self, color, time=0.5, iteration=1):
                time.sleep(time)
                time.sleep(time)
        This method can be called as:
        message('orange')
        message('orange', time=1.4)
        message('orange', 1.4)
        message('orange', time=1.4, iteration=6)
        message('orange', 1.4, 6)
        message('orange', iteration=6)  # which will use the default value 0.5 for time
        Note that this is not identical to your message(self, color) and message(self, color, time) methods because they do not have a time.sleep(time) after the LED is turned off. If that is necessary, use:
                time.sleep(time)
                if iteration > 1:
                    time.sleep(time)
        This Stack Overflow question has some other solutions
        https://stackoverflow.com/questions/6434482/python-function-overloading
          tttadam
          Thank you for the detailed answer!
          This is the best solution what I could find.
