    DeepSleep Current Consumption
    deepsleepdeep sleep shiecurrent consump
    2 Posts 2 Posters 648 Views 3 Watching
      spiderplant0
      Hi, I can only manage to get deep-sleep current down to 570uA (should be 10uA). I wonder if I'm missing something that needs to be deactivated prior to entering deep sleep. I've posted my code below...
      SiPy - v1.0
      Expansion Board V2.1A
      using deepsleep shield
      Firmware: 1.18.1.r1
      Using latest deepsleep.py
      Measuring current at the battery (USB not connected)
      import sys
      pycom.rgbled(0x020202)
      pycom.heartbeat_on_boot(False)
      pycom.wifi_on_boot(False)
      from deepsleep import DeepSleep
      ds = DeepSleep()
      def deepSleepTimer_handler( arg ):
          ds.go_to_sleep(10)
      from machine import Timer
      #Put into deepsleep after 20 secs (delay gives you a chance to upload fresh code)
      deepSleepTimer = Timer.Alarm(deepSleepTimer_handler, 20, arg=0, periodic=False)
        psychogenic @spiderplant0
        @spiderplant0 Hi,
        I can't speak to the specifics of your case--I'm using a bare GPy sitting on a custom board--but I've also been looking into deep sleep current consumption.
        I started a thread on the GPy board, where you can see my tests and results, but the short version is that with all the networks/peripherals down and doing a machine.deepsleep() the best I've gotten is also around the 0.5mA mark.
        This is a total guess, but it looks very similar to doing a deepsleep() rather than actually "pulling the plug" as that shield seems to allow for.
