How to restore to default interface?
 Hi
 I'm running pymakr 1.0.0b8 on Linux; I have by mistake clicked on 'Reset layout to factory defaults' in the preference pane, and now, I get a light grey interface with a completely different layout, and I don't even have the sync and run buttons.
 How can I restore the original layout? I tried deleting .eric6 and .pymakr directories in my homedir, uninstalling and reinstalling pymakr, but I always get the same ugly window. Thanks for your help Thanks for your help
 @jnc Thanks - I had a similar problem.
 I hadn't seen the ~/.config/Pycom directory.
 There doesn't seem to be a ~/config/Trolltech.conf on MacOS, but getting rid of the pymakr* files cured the problem.
 Thanks again for sharing.
 Brian
 Hi @jnc, Good that you found the solution right away :) I'll add this to the task list to fix the functionality of this button.
 Hi again,
 I thought I'd share the solution I found to my own problem :)running the following command did the trick rm -rf .eric6/ .pymakr/ .config/Trolltech.conf .config/Pycom/pymakr*
