    Is Gpy AT&T PTCRB certified?
    ptcrbgpyat&t
    4 Posts 3 Posters 636 Views 4 Watching
      pmjackson
      Hello Pycom,
      I see that Gpy is Verizon certified.
      With the new firmwares, Gpy is working much much better.
      I saw in an earlier post that you may be working towards PTCRB for AT&T.
      Any update on that?
        curtis.hendrix
        I know this is old and I don't have an actual answer to the question. However, I have had good luck connecting to AT&T's network with the GPy using a SIM from AT&T and from Hologram. Will the GPy work AT&T? Probably? Is it AT&T certified? Who knows.
        P 1 Reply Last reply Reply Quote 1
          pechan @curtis.hendrix
          @curtis-hendrix Could you share the code you used to connect to att with a hologram sim card?
            curtis.hendrix @pechan
            @pechan I used the CAT-M1 example code verbatim and it worked the first time through.
            https://docs.pycom.io/tutorials/lte/cat-m1.html
            import ssl
            from network import LTE
            lte = LTE()         # instantiate the LTE object
            lte.attach()        # attach the cellular modem to a base station
            while not lte.isattached():
                time.sleep(0.25)
            lte.connect()       # start a data session and obtain an IP address
            while not lte.isconnected():
                time.sleep(0.25)
            s = socket.socket()
            s = ssl.wrap_socket(s)
            s.connect(socket.getaddrinfo('www.google.com', 443)[0][-1])
            s.send(b"GET / HTTP/1.0\r\n\r\n")
            print(s.recv(4096))
            s.close()
            lte.disconnect()
            lte.dettach()
            Make sure you have updated the modem to latest: https://docs.pycom.io/tutorials/lte/firmware.html
            I had to use a micro SD card to update the modem. I couldn't figure out how to upload the files into the internal flash, but that was probably something I was doing wrong.
