    Serial communication using PySense
    pysenseuartrpihelp
    7 Posts 3 Posters 811 Views 3 Watching
    • M Offline
      Mellow
      Currently i am trying to communicate between a LoPy4 on a PySense and a Raspberry Pi using UART.
      I know how i would achieve this in code but the part i am stuck at is selecting the pins.
      https://docs.pycom.io/.gitbook/assets/lopy4-pinout.png
      Judging from the Pinout PDF provided for the PySense i know i can use the external IO header.
      Would it be as easy as just choosing two pins for example P10 and P11 and connecting these to my rpi using some cables? Or is Flow control also required which would mean i would select two more pins?
      Thanks in advance
      • M Offline
        Mellow
        Allright currently i have P10 and P11 connected to the RX, TX and ground to the GPIO of the pi and changed the pins in my code to this aswell. But when i run it none of the test messages arrive.
        Is there anything i am missing?
          robert-hh @Mellow
          @mellow Just to ask a silly question? Did you cross TX and RX?
          And a test. If at the Pysense connect TX and RX, can you receive what you send?
          • M Offline
            Mellow @robert-hh
            @robert-hh I just checked to be sure and can confirm they are swapped.
            Could you rephrase the second part of your question? i am not sure what u mean by that.
            This is the code i am running as far as i know i thinks this should work
            I connected the header pins 7 and 8 which correspond to P10 and P11 to my rpi along with GND
            uart1 = UART(1, 115200, pins=('P11','P10'), bits=8, parity=None, stop=1)
            uart1.init(baudrate=115200, bits=8, parity=None, stop=1)
            x = 0
            while x < 100:
                if uart1.any():
                    data = uart1.readall()
                    print(data)
                time.sleep(0.25)
                x += 1
            import serial
            with serial.Serial('/dev/serial0', 115200, timeout=10) as ser:
                ser.write(b'test')
              robert-hh @Mellow
              @mellow If you disconnect for a moment the rpi and just connect P10 and P11 on your Pysense. After init'ing the UART, if you then uart.write a short message, you shoudl be able to receive it with uart.read(). if that works, the you know the taha is getting out and in from the pysense. You could do a similar test on the rpi.
              • M Offline
                Mellow @robert-hh
                @robert-hh I managed to get it to work! Thanks for the help!
                I tried some code i found on the forum so i think it had something to do with my code in the end.
                I'll try to update this thread with the working code once i finished working on it
                • V Offline
                  Victor II Romero
                  HI Mellow, I would be very interested to find how you did this.
