    Persistent event logging
    loggingpersistence
    3 Posts 2 Posters 629 Views 2 Watching
      danielm
      I would like to implement persistent event logging into local file system. What approach to choose to achieve solution resilient to power outages? Using new LittleFS file system might help but I am a little bit concerned because there is also config file stored in the file system in case of our application. I was considering to move the config to RTC memory. Using NVS for persistent store of config is not an option as it currently supports only integers.
        Paul Thornton
        That should work. I'm sure your well aware already but you'll also need some kind of house keeping process to clear and/or sync the logs to a remote host after a while to.
          danielm @Paul Thornton
          @paul-thornton
          Thank's Paul, anyway it would be helpful to implement NVS support for string and blob objects. I think this is already available in the IDF.
          What's your opinion @iwahdan ?
