    Dead modem
    gpy dead lteno attachment
    7 Posts 4 Posters 645 Views 5 Watching
    • K Offline
      kjm
      The lte modem in my gpy will no longer attach. I've checked the sim is current &
      DL SYNCHRO STATISTICS
          Synchro state                         : DRX_SLEEP
          PPU SIB1 ACQ watchdog                 : 0
          Frequency Hypothesis RF  (Hz)         : -1000
          RSRP (dBm)                            : -122.70
          RSRQ  (dB)                            : -14.68
          Channel estimation state (Cell-spec.) : HIGH CINR
          Channel estimation state (UE-spec.)   : LOW CINR
          Channel estimation state (MBSFN)      : LOW CINR
          Channel estimation CINR               : 0.89
          Channel length                        : SHORT
        AGC
          AGC RX gain (dB)                      : 60.31
          RX PSD BO (dBFs)                      : -31.78
          RX PSD (dBm)                          : -125.68
          Noise level RS (dBm)                  : -119.08
          Digital gain (dB)                     : 18.00
          CINR RS (dB)                          : -3.62
        NARROWBANDS
          Last DL NB                            : Central
          Last UL NB                            : N/A
        AFC
          Frequency offset RF  (Hz)             : 549
          Frequency offset BB  (Hz)             : 0
        PBCH
          MIB received quantity                 : 63
          MIB timeout quantity                  : 0
      is the AT!="showphy" return. Is there a way to pin down what the problem might be? I'm not seeing any power out of the lte antenna, is there a way to test for a failed RF transmitter in the sequans?
      • E Offline
        Elizar @kjm
        @kjm What about "power in" of the Gpy? There is a large power consumption spike when Gpy attaches to the net.
        • K Offline
          kjm @Elizar
          @elizar I got another gpy & it's OK, so either something has failed in the first one or there is some setting in there that's different.
            cdyrssen
            @kjm It seems like I'm running into a similar issue. I was wondering if you had any luck debugging if it was the modem that actually died or a settings issue?
            • K Offline
              kjm @cdyrssen
              @cdyrssen Was never able to revive that modem, it responds to firmware upgrades but never attaches. I use that gpy still for software development since the wifi is OK.
              • R Offline
                rskoniec @kjm
                @kjm Any interest from Pycom (forum chat maybe)? Definitely they should react/be interested. Maybe you should reach @Xykon, @dan, @Bettina or @Fred.
                • K Offline
                  kjm @rskoniec
                  @rskoniec Mate I'm paddling hard to keep my head above water with the continual state of pycom/sequans firmware flux without trying to follow up on a single failed piece of hardware. Typical of most hybrids I reckon the RF wafer is probably heaps more fragile than the digital stuff & a glitch down the antenna feedline or on the 5v rail has cooked it. Probably the only disadvantage of having the lte integrated with the smarts on the same board.
