    What is the actual max current available on the 3v3 output, assuming worst case GPy current consumtion
    gpypower supplypowercurrent consump3v3
    2 Posts 2 Posters 416 Views 3 Watching
      curtis.hendrix
      I'm seeing 2 conflicting specs for the max current available on the 3v# output. The pinout diagram and datasheet for the GPy says it is 1.2A.
      But the order page for the GPy (https://pycom.io/product/gpy/) says 400mA.
      What's the actual max current available on the 3v3 output? Under the assumption that the worst case power draw of the GPy hardware has always been satisfied.
      • E Offline
        Elizar @curtis.hendrix
        @curtis-hendrix I have no spec but I once tried to connect a small LCD display to that power pin. That was an instructive failiure. Even 400 mA is optimistic (may only be reachable at the limit of 5.5 V Gpy supply).
        You can safely use that 3.3 V pin to supply some I²C chips but nothing that needs power.
