    RGB LED + SPI not working
    rgbledspiwipy
    3 Posts 2 Posters 482 Views 1 Watching
    • M Offline
      Martinnn
      I'd like to use both the RGBLED and the SPI interface separately (for controlling an external display) on the WiPy. Initializing the SPI interface disables the RGB LED:
      from machine import SPI
      pycom.rgbled(0x404000)
      spi_display = SPI(0, mode=SPI.MASTER, baudrate=8000000, polarity=0, phase=0, pins=('P9', 'P8', 'P2'))
      while 1:
          pycom.rgbled(0x004000)
      The first rgbled call works (yellow), the second one (green) doesn't. Commenting out the SPI initialization makes it work again.
      Any ideas?
      • FridaF Offline
        Frida
        If you look at the pinout, you will see that P2 is used for the RGB LED.
        https://docs.pycom.io/.gitbook/assets/wipy3-pinout.pdf
        • M Offline
          Martinnn
          Stupid mistake, I thought I had checked the pinout... thanks!
          Set it to None and now it works.
